- Joined
- Apr 21, 2026
- Threads
- 23
- Messages
- 169
- Reaction score
- 114
- Location
- LA
- Website
- www.facebook.com
- Vehicle(s)
- 2026 Tacoma TRD Sport
Hi everyone, Jeremy here.
We’ve been working on a few new Tacoma accessories that focus more on solving small, everyday annoyances than simply changing the look of the truck. Four of them are getting close, so here’s a quick preview before launch.
Tailgate Anti-Theft Lock
A simple extra layer of security for the tailgate hinge area.
The carbon-steel bracket creates a physical barrier that helps make quick tailgate removal more difficult, while still allowing the tailgate to open and close normally. It uses the factory mounting point with no drilling, and a 10mm L-shaped socket wrench is included for removal or adjustment when needed.
Air Vent Storage Tray ( Driver side and passenger side )
For 2024–2026 Tacoma 4-Door models.
We didn’t just add a convenient spot for keys, cards, coins and other small items. We also made the tray larger, added a removable silicone liner to help cut down on rattling, and used silicone contact pads on the back to keep the tray firmly seated. The taller edge also helps keep smaller items from sliding out under braking.
4PCS Rear Bumper Crossmember End Caps
A small upgrade for some pretty exposed areas underneath the rear of the truck.
The 4-piece set closes off the exposed crossmember openings to help keep out mud, snow, water and other debris. We chose TPE because it‘s better suited to long-term outdoor exposure and seasonal temperature changes, helping the caps maintain their shape and stay securely fitted over time.
All-Weather Floor Mats
Designed for 2024–2026 Tacoma Gas Double Cab models with automatic transmission. Not for Hybrid models.
Made from TPE for all-weather protection. The raised-mold forming process helps the mats hold a more defined, stable shape, while non-compressed packaging helps reduce deformation during shipping.
Which one would you pick first?
Feel free to leave a comment below and join the Mabett 4th Gen Tacoma Garage If you want to see more early Tacoma product previews, selected testing opportunities and member-only offers.
We also use silicone contact pads on the back to ensure the tray seated firmly.
