Remove water spots from paint?
sdreher
stephen
alabama
2024 sport
24 Tacoma Sport has about 18 square inches where water spots have developed in front of the hood scoop. I have tried Chemical Guys and several other products including buffing. It helps for a short while, but they come back. Is there a remedy to remove them?
EVOTACO
Jay
'24 Taco TRD OR i-FMAX, '14 EVO X
We have fairly hard water out here in AZ. I have had success with using a clay bar to remove water spots, but if the clear coat has been chemically etched by something, polishing or the more aggressive compounding is the only way I know of to correct it.
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
I would research professional car detailing products to remove water spots, there are plenty available. If you’re washing your car (or going to a car wash) hard water (minerals/impurities) causes water spots. you can prevent them with using soft water to wash, PPF and/or ceramic coating.
sdreher
stephen
alabama
2024 sport
Thaks for the info. I'm a little concerned because I've never hqd a problem on other Toyotas
EastonTaco
Venice FL & Easton PA
I had the same problem on the hood. I clayed the hood to remove anything that was there including previous waxes. Then applied Griots Garage Best in Show carnauba wax and use their Speed Shine between waxes. Problem solved.
Brent@ANParts
Brent
www.autonationparts.com
Ford Bronco
Definitely give the clay bar a shot, I've had decent success with that. I'm in AZ (also mentioned before) and yeah, the water hardness is ridiculous out here.
