Trainer Steve Clifford
Virginia
22 RAV4 XSE
I had some time on a rainy Saturday to look at the new Tacoma and noticed that there are some new features packed into the MID. I'm particularly impressed with the pitch and roll gauges on a non-TRD Offroad model.
stillgotomx
Mark
New Mexico
Hey Steve, really appreciate all your vids, and finally mastered setting up the new Multi-information-display, only to find that I lose all the settings as soon as I turn of the Tacoma.....Is there something I am doing wrong, or is this a resolvable issue? thx
Virginia
22 RAV4 XSE
There are two settings that will not "sticky" in the system. The tire pressure monitor and the maps will disappear. The maps will come and go but the tire pressure you just have to find when you want it. I didn't put that in the video because I had honestly forgotten that this happens. Toyota is aware of it and it isn't exclusive to the Tacoma. Every new Toyota with the 3 panel MID does this.
stillgotomx
Mark
New Mexico
Well, I was including the tire pressure in one of those, so I'll take that out and see if there is a difference. But meter settings, like the appearance of the dials, goes away every time, and invariably, the MPG information comes back to present itself every time, and I really don't want to see that. This whole MID set up is frustrating in that things don't "stick" as you put it. Thanks for you expertise!
Tacoflvrd
South carolina
2024 TRD sport
That’s weird. I have changed mine several times and it always stays on what I change it to. I did just recently get my truck though. Maybe they updated the software before I got it?
Zanez
Zane
Cali
I have the same problem with the MID sticking. I wish you could make the settings to pull up the same screen as when you got out of the truck.
stillgotomx
Mark
New Mexico
total drag...I'm sure some kind of software reset could fix it. Would removing and replacing the battery cables do it?
Virginia
22 RAV4 XSE
Not likely. This same issue exists on every Toyota with the 3 panel multi-information display. It is a known issue and the engineers seem at a loss to solve it.
ridetime
Oklahoma
Sort of a different problem but how about the "custom" drive mode settings in the Limited trim that don't allow you to customize them? Do you know if Toyota is aware of this issue?
