I installed one of these with some 1/8in killMat rubber sound matting on underside. Makes a significant reduction in injector noise / engine clatter under acceleration.
I assume that these brackets are made of 6061-T6 aluminum. Steel wouldn't crack that easy. Did they send you a new bracket? I don't understand why they made the top plate out of two pieces.Had to take mine off... i was hearing vibrations from inside the cabin and couldn't figure out where it was coming from... After 6 months with it, the metal snapped on it. Reaching out to Victory now to see.
Ease of manufacture. Far easier to make multiple bolt together parts that obtuse complex shapes, especially when stamped.I assume that these brackets are made of 6061-T6 aluminum. Steel wouldn't crack that easy. Did they send you a new bracket? I don't understand why they made the top plate out of two pieces.
Why not?Could you spray paint this?
