trailhunger
2024 TH
Have to say impressive it maxes at 120psi. The roadies are gonna love this. Hooked up a 10 gal expansion tank and it eventually got there, net time ~13min w/ some cooldown breaks in between. The unit does have a hard time reading PSI off the line to the tank / had to disconnect & reconnect to get a reading.
As far as I can tell the compressor runs direct off the engine battery based on some display prompts.
One wrinkle is in the setting relating to the power ports in ā€˜manual’ or ā€˜auto’. Need to dig into this as I have a couple possible applications for that cigarette lighter port once my GFC is loaded…
2024 Tacoma Maxing the Trailhunter Onboard Air Compressor @ 120 PSI IMG_6531
2024 Tacoma Maxing the Trailhunter Onboard Air Compressor @ 120 PSI IMG_6532
BuriedFriend
Stevie
texas
24 Tacoma TRD Pro
That’s pretty impressive. Does anyone have the part numbers for this and can it be installed in a pro?
Avery
rhode island
2024 Tacoma Trailhunter
Does your cover on your air compressor stay closed or does it flap around while you’re driving? Toyota has told me it’s normal for it not to close
trailhunger
trailhunger
2024 TH
Stays closed, not the most full proof lid I admit, but I have a gfc over the bed
