AlphaRex Lights - TRD Pro
rijc99
If I have time I’ll probably connect the two wires to a toggle. But that requires waterproofing the plate then running the wiring to maybe inside the cab. Access panel is under the light so it’s a pain to swap.
Taco Ji
New Jersey
2025 Toyota Tacoma
Better than OEM. Cutoff is more defined so it’s a toss up since I have more light on the ground but everything above the line is no longer illuminated.
It can do Amber. I initially had amber but felt it didn’t fit my silver truck so I switched it to white. I would have preferred to no have the bottom bar light up but it’s ok. I wish they had connected the two white wires to a toggle in back so we can switch white/amber without having to remove the light.
The app requires another module that isn’t available yet. It might be relesased after sema.
Thanks. I actually like the amber on your silver better. It gives it a better contrast!
I’m hoping Alpharex will have a Black Friday sale on these so I can pick up the headlight and taillights at the same time.
