Build quality issue or "by design"?
Drakka01
Scott
Ohio
So I noticed the roof spoiler seems barely attached. Seems like it's probably mostly 3M taped on or something (didn't take it apart to confirm anything). Regardless, there's a significant gap between the cab and the spoiler as well as the spoiler doesn't actually line up vertically with the top of the cab. When I wash the truck, water runs down between the cab and spoiler then down the back window. It seems like it is kind of drooping on the back (see the angle vs. the black seal at the far side in the first pic) which seems like it's a result of it pulling away from the cab along the top.
None of this is necessarily a problem. Just wanting a baseline to make sure this isn't a QC issue specific to my truck while it's still fresh from the dealer and I can probably get a remedy at their/Toyota expense if it is a QC issue.
How does yours look and feel?
2024 Tacoma Build quality issue or "by design"? 20240415_163340
2024 Tacoma Build quality issue or "by design"? 20240415_163359
2024 Tacoma Build quality issue or "by design"? 20240415_163410
Dansflhti
Nova Scotia
I don't want to ambush this thread..but I've noticed the two black trim pieces that run the length of the roof, stop about 6" from the windshield. Kinda looks unfinished.
Drakka01
Drakka01
Scott
Ohio
Mine don't even run the length. They are 4 pieces about 1 ft each covering the bolt holes with color matched paint in the rest of the channel. Looks a bit odd from the top but I have a roof rack ordered from Westcott so they will be removed anyway.
Dansflhti
Nova Scotia
I never got in the back of the truck and checked the complete length.. I just assumed it was short at the windshield. I don't have my truck yet..get it Thurs or Fri.
lb272
Iowa
24 OR MT
I have the 4 pieces as well. At a glance It seems like an odd choice by Toyota not to run full length trim on the roof rail channels. Looks like water could just sit in the middle on top (between the individual trim pieces) and the since the front portion of the channel intersects with the windshield seal, a potential vulnerable spot for water to get in the cab. Maybe I'll get out the hose and see what happens....
Drakka01
Drakka01
Scott
Ohio
Looks very similar in this video so definitely seems intentional. I will say that it actually looks better on this lower trim that uses the black spoiler instead of body color. Since there's a color contrast, the alignment shift looks intentional rather than just a misalignment.
Perhaps the gap is intentional to keep it from vibrating/squeaking against the cab. The whole part just feels flimsy and cheap though. I guess we'll see if it holds up over time.
