Cig Lighter/12v Removal
Bangingparts
Keith
IN
2024 TRD OR
I am trying to tap into the power of the back of the cig lighter. Has anyone removed it, what is the best way to either pull it out or get to the plug from the rear?
The whole panel where the cigarette lighter and wireless charger (if equipped) comes out/off relatively easily. Just have to get a plastic pry tool as it is attached just by clips.
Bangingparts
Keith
IN
2024 TRD OR
Pull straight out? Toward the rear of the cab?
No screws?
No screws?
Nope, no screws.
What worked for me was using a pry tool on the sides to get the top corner(s) loose, then work the top corners to get the actual top of the panel to pop out. It will eventually pop loose and you remove it up and at an angle towards the gear shifter.
hogshooter
Corey
Plant City, FL
2024 Tacoma Limited 4x4
Nope, no screws.
Do you need to remove the shifter tray first?
