Drivers Side Tap Tap Tap... AI was right! Cause was Loose Splash Shield
webshot
Jeff
Northern California
2024 Tacoma Limited
Probably "Known" to some of you, but I had a tapping/clicking noise on the drivers side of my truck while driving. I did the google AI thing on the subject and it was actually right this time!...
"Loose Splash Shield (Most Common): A common issue causing a "tap-tap-tap" or fluttering sound near the driver's door/front fender is a loose splash shield, often caused by weak factory plastic grommets."
Solution: I replaced the factory plastic grommets with some after market grommets that come in this kit...
https://www.amazon.com/dp/B07ZD33HK6?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_3&th=1
Issue resolved!
Have fun!
