High Lift Jack Points
EastonTaco
Venice FL & Easton PA
Just got my Gen 4 TRD Sport. I’m not a hardcore off roader, just need 4WD for bad weather and occasional easy trails hence the Sport and not OR. I doubt I will ever need to use the rear high lift jack points. Any thoughts on a plug/cover similar to a hitch mount cover to dress up the rear end a bit. Current Mods:
Removed Sport air dam
Custom TRD Skid Plate (This guy only sells on ebay and it’s the best fitting Sport plate out there) note this is not a super heavy duty plate but it also installs without the need to add a crossmember to the Sport and meshes perfectly with the lower half of the bumper. Perfect if you’re not grinding over rocks.
OEM lighted front emblem
OEM Exhaust tip
BacFlip X4 bed cover
OEM Mud flaps
