Jack stands
Someguysomewhere26
united states
2025 tacoma SR5
Do you guys use 3 ton or 6 ton jack stands?
I only ask as I have a pair of newish 3 tons already and and hoping I can just get another pair of 3 ton for a full set.
Or if I need to suck it up and get 6 tons.
JoeMongo
Jonathan
SF Bay Area
2024 TRD Offroad, Premium, MT
If each of your jack stands are rated to 3000 lbs, you should be fine.
OminousSkitter
Alaska
You have an SR5 (not a hybrid long bed). Unless it's loaded down with things like a camper, you're nowhere near 6000 lb (3 ton). A full set of 3-ton jack stands should be fine. Even a stock Trailhunter long bed (~5400 lb) should be OK on 3-ton stands assuming it isn't loaded down with gear.
Just remember, most jack stands are rated per pair. This still means 3-ton stands work for you, but that isn't 3 ton per stand unless explicitly stated as such (which is rare).
Ray T
Ray
24 tacoma pro
Depends on how high you need the stands t go also with larger tires it adds some extra height to your frame
CharlieLed
Chucki
TN
2025 Tacoma
More importantly, the stands should NOT be 3-leg tripods. Don't see many tripods in use any longer but still see them for sale on CL and FB.
Will721
Quad Cities
This right here. Obviously, weight rating is important. But I choose jack stands by height first, then just make sure they can hold thr weight I need. A tall collapsed stand is safer than a small extended one of any size.
Plus, if you do major work, nothing beats being able to sit under a rig rather than being on your back. For example, my spare tire no longer fits. When I put my rig on my big stands I'll be able to sit there and clean out the diff when its time.
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
I’m using 6-ton Daytona jack stands because the footprint is bigger, plus they are taller if I need to lift high. The wider footprint makes me feel safer than if I were using the 3-ton size.
