Limited 2024 Rear shock question
Tacomanoob
Daryl
4G Tacoma
I have a problem with my rear shock. I have LEER camper top and the weight of the camper is making the back of the truck bottom out when i go over speed bumps. I tried to install Timbren camper bump stop which was a fail, the weight of the camper just made the bed drop so low there is no travel. So decided to change the shock to bilstein B8 5100. I noticed that factory shock absorbers have AVS in the front and rear. How would I go about replacing the shock with bilstein 5100. Just unplug the rear, would I get a warning light, would that interfere with the ride quality?. Can someone give me advice on how to go around it. Thanks
CEtaco
Coy
United States
2024 Tacoma Limited
I don't have an answer to your question, my apology. I am also curious about the same thing. However, I installed the Firestone ride-rite system a few weeks ago for basically the same reason and love it. I had one on my last Tacoma as well. You might want to look into that instead, It would increase your capability instead of creating a work-around. Just a thought.
You bring up some interesting questions. First, I would try disconnecting the rear shocks to see if you get any warnings. Regardless, if you decide to replace the shocks, you’ll probably need to do all four corners and take AVS out of the equation completely.
lpsoldia311
Chief
North Carolina
25 Tacoma Limited, 16 4Runner Trail
You probably need to swap to higher spring rate coil springs, or longer springs with same spring rate in order to compensate with the added shell weight. The shocks are for dampening and cushioning the ride primarily, with some adding some lift options like the 5100's but would give an error I'd imagine. That way you keep the electronically controlled shocks in operation and get back to normal ride height.
Cappaworks
2026 Tacoma TRD Off Road
I’ve had a similar issue with a large cooler, rooftop tent, firewood and a UTV trailer. The real solution involves a higher coil rate, especially for you since you likely won’t take the truck cap off regularly. ARB/Old Man Emu offers a couple different coil rates for stock height trucks to accommodate heavier loads. However, with the increased load weight and new higher spring rate, you’ll also want to increase shock valving. High end aftermarket shocks with compression adjusters, such as the Fox Performance Elite with DSC adjusters are the most versatile.
Tacomanoob
Daryl
4G Tacoma
How do you over come AVS module on the shock is my question. Any solution would be great. I will look into old man emu coil springs. Thanks for that.
