Benny
Jay
Oregon
You sure about that? I thought it would be available with a 6’ bed. With the hybrid not available yet, how would anyone know for sure since the hybrid option isn’t in the configurator. Honestly I’m hoping for the same truck as you if the TH is too pricy or comes standard with features I don’t want on it.
Chatted with a regional Toyota Rep at the Portland Auto Show, he confirmed the TRD OR Hybrid would only be available in the 5ft Bed - which was disappointing.(n)
My understanding is that only the TrailHunter would be available with the 6ft Bed Option. (n)
He also said the Wireless Trailer Camera System (Triple Shark Fins) would only be available in the Halo Models.(n)
JED
Southern Tier NY
2015 Tacoma TRD Sport
Made a special trip down to Phoenix, AZ to get the truck outfitted at Westcott Designs where we got some test fitting done. Couldn’t be happier with the result. I would recommend Westcott 10/10 times. Their customer experience is top tier and their products are unmatched.
Westcott Designs Preload Collar Lift
Toyo Open Country AT3 285/75R17
Method 703 17x8.5 +35 offset (pokes exactly 1” outside of the fenders)
No rubbing
Another new video:
Updated with @1106garage's 2024 Tacoma build video
2024 Tacoma 4th gen build Toyo Open Country AT3 285:75 and Method 703 +35 offset 1.jpg
2024 Tacoma 4th gen build Toyo Open Country AT3 285:75 and Method 703 +35 offset 4.jpeg
2024 Tacoma 4th gen build Toyo Open Country AT3 285:75 and Method 703 +35 offset 3.jpeg
2024 Tacoma 4th gen build Toyo Open Country AT3 285:75 and Method 703 +35 offset 2.jpeg
Now that you’ve had some time with your truck build do you have any additional feedback. I’ll be having the same build completed on my bronze oxide OR long bed Monday.
sierraenvy
Nevada
Will adaptive cruise and lane tracing continue to work with these lifts/tires?
lefromagepuant
Roland-Louis
your rearview mirror
2 tacos with a side of beans
Thank you for showing me how an SR5 is a winning alternative to higher-cost trims. It's not about the extra spend as much as how much bang for your buck you get with the SR5. Thankfully, you're not in my area because it'd be awkward if we ran into each other driving nearly identical trucks. Great work, and stay golden.
cdane
Austin, TX
2025 Tacoma
No rubbing
Another new video:
Sweet...did you use specific hub centered rings for the 106.25 to 95.1 mm bore difference?
