Noise turning left
Total BS on it being normal. If it is normal then why doesn't my truck do that?
It seems like Toyota must be training their dealers in lying to customers, rather than in fixing their vehicles these days. A LOT of people are getting the old, all the other crap on the lot do that too routine.
Arizona
2025 Trailhunter
Update:
Service Center #1:
1st visit: They claimed they didn't hear the noise.
2nd visit: I test drove it with a tech, they confirmed the noise, kept it 1.5 days then told me it was "normal'.
Service Center #2:
I described the situation in the same way. They had it for less than a day and
they removed the front strut springs and lubricated contact points. From limited testing today I didn't hear the noise. I'll report back if that changes. They also fixed a rear seat latch that service center #1 also couldn't fix. Needless to say I'll be driving the extra distance to use service center #2 from now on.
Zebrajacket99
IL
2024 Trailhunter LB
I've had this as well for the past several months. Thought it might have been the skid plating contact points but its always seemed like more of a suspension related item.
Arizona
2025 Trailhunter
After a weekend of off-roading some similar slow-speed-turn metallic noises returned. I went back to the shop and they are gone again, for now. They said it was a different noise source than before.
Zebrajacket99
IL
2024 Trailhunter LB
Mine did in fact end up being the skid plates. 21ft lbs is the correct spec. I over tightened them . . . twice. Lesson learned. Surprising they made that much racket when flexing until they were loosened up a bit.
departureown9072
Andrew
North Carolina
2026 Trailhunter
Any update on this? I have a 2026 TH and it is making this same "popping/thumping" sensation in the steering wheel when turning 45 degrees. It is worse when turning left but will happen when turning right sometimes. Thanks!
