OEM Power Running Board Removal???
Eesh29
2025 Tacoma Hybrid Limited
I know this is going to sound dumb, but I'd like to replace the power running boards on my 2025 Limited with stationary ones to help protect the side of my truck from rocks. The power ones will probably just freeze up and corrode in the winter anyway.
If anyone has removed theirs, what did you do with the power cables as far as securing them and water proofing the plugs? Where you able and how did you shut off all the dash messages?
ridetime
Oklahoma
I removed mine. Pretty straight forward. I used waterproof tape to thoroughly wrap the connections and zip tied them to the underbody. I did this for rock protection and in combination with rokblokz mud flaps i can drive down dirt/gravel roads at 40 all day long with zero chips.
Turn your running board switch to off. Be aware that you will get an error referencing the running boards but if you keep the switch in the off position it will go away after several key cycles. Mine have been removed for almost 2 years now with no errors after the initial 5-10 ish cycles.
grwil67
Gary
Louisiana
2024 Tacoma Limited, 2018 F150, 2019 Roadking along with a few older F150s and H
I would store them away safely as it may help later in resale or trade in. Very nice looking power operational running boards could make the sell.
