Phone Battery Low
GPTaco
Alberta Canada
2024 TRD Sport Premium
Recently had this error message display, my phone battery was at least 70% or better each time this has occurred.
docadams225
Ryan
Hammond, LA
I would just perform a restart on the device, change cords, and see what happens.
If you have a Samsung, you can do diagnostic checks on the charging port through the settings too.
GPTaco
GPTaco
Alberta Canada
Service appointment this morning at my dealer so will get their feedback but I think your suggestion is likely correct.
Thanks
JamesA
Memphis
2024 tacoma Limited
Mine started doing same thing a couple of days ago. Have not figured out cause. Phone is charged over 80%.
GPTaco
GPTaco
Alberta Canada
I'm at Toyota dealer for service this morning im going to ask about it.
Tried phone restart and disconnect from truck but no change so far.
Richardb106
Richard
Yuma, Az
It's android auto problem. I found threads on other vehicles as well having the same issue including subarus. If you look at the play store for the android auto app there are also negative reviews that speak of this same issue. I was thinking mine got messed up when I installed the beat sonic amp. Glad I didn't take everything apart to remove it! I'm sure this problem will be fixed in a future update from android auto
GPTaco
GPTaco
Alberta Canada
It's android auto problem. I found threads on other vehicles as well having the same issue including subarus. Off you look at the play store for the android auto app there are also negative reviews that speak of this same issue. I was thinking mine got messed up when I installed the beat sonic amp. Glad I didn't take everything apart to remove it! I'm sure this problem will be fixed in a future update from android auto
Thanks for the info, my dealer hadn't seen this issue yet and found no TSB's on this problem
Senray
New York
Anyone having problems with the wireless Qi charger? Mine charges for about 30 seconds and stops
SnowmanJPS
Halifax, NS
2025 TRD Pro
I noticed mine starting to do that today, I'm trying to hold out for sales to upgrade to the 3d printed magsafe holders
