Protect Your Transmission: Mishimoto’s Solution for the 2024+ Toyota Tacoma
Panda Motorworks
O'Fallon MO
2025 Tacoma SR5
If you’re pushing your 2024+ Tacoma with towing, hauling, or off-road adventures, keeping transmission temps in check is crucial. The new Mishimoto Performance Transmission Cooler is designed to do exactly that, improving reliability and protecting your transmission under demanding conditions.
Why a Transmission Cooler Matters
Automatic transmissions generate a ton of heat, especially under load. Excessive temperatures can lead to fluid breakdown, slippage, and premature wear. By lowering transmission fluid temps, you help your Tacoma shift smoother, perform better, and extend its lifespan. Which is particularly important for anyone who tows, drives in hot climates, or hits the trails.
Key Features
  • High Capacity Tube-and-Fin Core: Internal fins maximize heat dissipation and reduce fluid temperatures before they even reach the stock radiator cooler.
  • Direct Fit Design: No cutting or fabricating needed. Comes with pre cut hoses, durable hose clips, and thick 3mm mounting brackets for a factory-like installation.
  • Quality Construction: Transmission lines meet SAE J1532 standards for durability and leak free performance.
  • Corrosion Resistant Finish: Each cooler is powder coated and built to withstand harsh weather, mud, and road salt.
  • Made & Tested in the USA: Engineered for real world conditions and backed by the Mishimoto Lifetime Warranty for peace of mind.
Real World Benefits
  • Reduces strain on the stock cooling system
  • Helps maintain consistent transmission temps under load
  • Extends fluid and component life
  • Improves reliability when towing, hauling, or off roading
If you want to protect your investment and keep your Tacoma running strong for years to come, this is a simple, effective upgrade that delivers real results!
Mishimoto Transmission Cooler – 2024+ Toyota Tacoma
Panda Motorworks
Panda Motorworks
O'Fallon MO
2025 Tacoma SR5
Don't forget, our Black November Sale is LIVE. This is a great chance to get one of these at a discount! :)
Drifte
Colton
Iowa
Looks like a nice setup. If theirs space for a thermal bypass in the kit Id be sold. Is their a specific Mishimoto model bypass valve that might work best?
izzy
Bay Area
When my current transmission shits the bed at 80,000 miles and the extended warranty gets me a new one this will go on Day 1 :cwl:
Panda Motorworks
Panda Motorworks
O'Fallon MO
2025 Tacoma SR5
They typically have one available with most of their kits. Doesn't look like that is the case with the new Tacoma kit. Why? Not exactly sure.
