- Joined
- Oct 1, 2025
- Threads
- 28
- Messages
- 85
- Reaction score
- 33
- Location
- O'Fallon MO
- Vehicle(s)
- 2025 Tacoma SR5
If you’re pushing your 2024+ Tacoma with towing, hauling, or off-road adventures, keeping transmission temps in check is crucial. The new Mishimoto Performance Transmission Cooler is designed to do exactly that, improving reliability and protecting your transmission under demanding conditions.
Why a Transmission Cooler Matters
Automatic transmissions generate a ton of heat, especially under load. Excessive temperatures can lead to fluid breakdown, slippage, and premature wear. By lowering transmission fluid temps, you help your Tacoma shift smoother, perform better, and extend its lifespan. Which is particularly important for anyone who tows, drives in hot climates, or hits the trails.
Key Features
- High Capacity Tube-and-Fin Core: Internal fins maximize heat dissipation and reduce fluid temperatures before they even reach the stock radiator cooler.
- Direct Fit Design: No cutting or fabricating needed. Comes with pre cut hoses, durable hose clips, and thick 3mm mounting brackets for a factory-like installation.
- Quality Construction: Transmission lines meet SAE J1532 standards for durability and leak free performance.
- Corrosion Resistant Finish: Each cooler is powder coated and built to withstand harsh weather, mud, and road salt.
- Made & Tested in the USA: Engineered for real world conditions and backed by the Mishimoto Lifetime Warranty for peace of mind.
Real World Benefits
- Reduces strain on the stock cooling system
- Helps maintain consistent transmission temps under load
- Extends fluid and component life
- Improves reliability when towing, hauling, or off roading
If you want to protect your investment and keep your Tacoma running strong for years to come, this is a simple, effective upgrade that delivers real results!
Mishimoto Transmission Cooler – 2024+ Toyota Tacoma
