Pics! Update May28/26 Reliability issues truck 1 rear driveshaft, truck 2 blown rear main seal
fletch
ontario canada
2026 offroad
Hi all. I must have the worst luck in the world at the moment.
I bought a 2025 trd sport last November in Ottawa Canada and had a vibration the dealer took 5 months to diagnose. I ended up trading it in after the replaced driveshaft still didn’t eliminate the issue totally. The dealer gave me what I paid.
I bought a 26 off-road plus and this morning driving into work someone told me to pull over as oil was showering out of my pan area. It turned out to be engine oil. Lucky me I didn’t run it dry. Anyway it’s now towed into Renfrew where I live and I’m waiting to hear what the issue is. I’m betting rear main seal as there was no oil by the filter and I still had some oil showing on the dipstick. Crazy. Two trucks both with bad QC QA issues.
tech456
Sucks to hear that. It wasn't leaking anything where its been parked prior to that drive? I saw someone recently mentioned their oil drain plug wasn't very tight from the factory. Hope its something simple.
fletch
ontario canada
2026 offroad
Nothing in the driveway. Not a drop. The only odd thing I can remember is a slight burn off smell I thought was just new truck burn off but now given what’s happened I’m assuming was a small seal leak. After I shut it off the oil stopped leaking and I still registered a small amount on the dipstick. The guy just flagged me over on the highway and I pulled over to check. If it was drain plug I’d assume it would be running out.
395North
TRD PreRunner
CA
2025 TRD PreRunner
That's some real tough luck.
My 25 Prerunner has been nothing but solid.
CharlieLed
Chucki
TN
2025 Tacoma
It was nice of the dealer to buy back your first truck for what you paid, as for the second. I would be interested to learn what is the cause of your leak. This has to be very disconcerting because we buy these trucks because they are built well and hold their value. Keep us posted!
fletch
ontario canada
2026 offroad
So my local dealer was able to tell me that there is a severe oil leak (duh) coming from the bell housing. So likely rear main seal. Service manager (who I respect) said “It wasn’t leaking. It was POURING out of the bell housing”. So I have a claim in with Toyota Canada. They haven’t offered me a rental or anything yet.
ScottyMcfly
Scott
Western Mass
2025 Tacoma
That's crazy. Keep us posted
ScottyMcfly
Scott
Western Mass
2025 Tacoma
My truck is being transported to a different dealer to expedite the diagnosis and repair. Toyota Canada is very aware my position moving forward. It’s been extremely frustrating. They did approve me for a rental and I just got it today. No other updates.
At least you have a rental
EagleTalon
2025 Toyota Tacoma Off Road
Truck repaired and back together. They road tested it , drove 30-45 kms and it’s blowing oil again.
Wow, yeah the rear mail seal is probably not it. I wonder if it’s too much crank pressure that’s causing it to blow and leak oil. Bad PCV? Piston rings?
