During transportation, the goods are prone to sliding within the cargo box, which may damage the goods and also wear down the inner walls of the box. This reinforcement bracket provides more anchor points for your Tacoma truck.
The Bed Rail Corner Gusset is compatible with 2024 2025 2026 Tacoma and also compatible with 2022 2023 2024 2025 2026 Tundra.
Provides additional anchor points to secure ropes, hooks or straps, effectively preventing the goods from shaking during transportation. It can also reinforce the weak structure of the front corner of the cargo bed, preventing the sheet metal from cracking due to severe off-road vibrations. This makes the transportation process safer.
Made of high-quality carbon steel, featuring excellent impact resistance. The surface is treated with a powder coat, providing outstanding corrosion and rust resistance. The structure is stable and does not deform easily during long-term use. Installation is simple and no drilling is required.
Get yours here:
Black: https://www.amazon.com/dp/B0H79NP42M
Red: https://www.amazon.com/dp/B0H798MGXK
Get yours here:
