Are the m5 bolts mounted with the threads facing up? Or secured with nuts under the bracket? Where would I use washers?
I don't recall the length of the bolts.
The holes in the truck are threaded. Put washers under the bolt heads. I don't recall which direction the ARB bolts go, but they need to be installed before bolting the bracket to the truck, if I recall. Yes, place washers next to the nuts as well.
Tatanko
Jessie
VA
Tacoma 4th gen
I’m excited to print and try this out. Thank you so much for creating and sharing the mount.
Tatanko
Jessie
VA
Tacoma 4th gen
Has anyone greated a mount for the switch? I's like to place the switch close to the compressor.
m1keaveli
cali
2024 offroad
m1keaveli
cali
2024 offroad
just an update to using this bracket
i managed to fit the ARB bracket (black bracket thats attached to the ARB assembly) to the 3d printed bracket using M5 x 16 allenhead bolts , washer under the bolt head, and nuts under the 3d printed bracket. just used whatever nuts i could that that would fit, but MAYBE locking washers would be a good idea.
mounted the 3d printed bracket to the engine bay using whatever bolts and washers that came w/ the compressor, i believe they are m6x30. they just thread in into wheelwell area so you length is negligible.
instructions actually indicate M5 bolts to bolt the compressor , but doesnt specify the length.
hope this helps whoever is using this awesome bracket, thanks again OP!
