Toyota Key Card Sleeve - What Are You Using to Carry it?
jimmy115
Jaime
Oregon
Tacoma TRD Off Road 2024
I have this mag safe wallet from Amazon. Built in find my tracker and is rechargeable. It’s a nice stiff hinge to use as a prop and the key fits inside. Starts very slim but I have a lot of cards in mine.
what brand? link please
goin2drt
KY
My code 118 wallet blocks the keycard signal, have resorted to carrying two wallets albeit thin.
Do you have it on the outside like mine? I have not found that to be the case. I mean even once in a while when I touch to lock the door it doesn't lock instantly but that is it.
Tacoma25
Michael
Naples,FL
Toyota Tacoma
Yes I tried it on the outside under the strap like you. Truck won't unlock or lock unless I pull out the card and hold it close to the handle.
I meant the whole wallet I was using not the keycard itself ,that works flawlessly on it's own.
VT Taco
Vermont
2025 Tacoma
I don’t see the need to put it in anything, just drop it into my pants pocket….
Rhood186
Ryan
Montgomery County, PA
The Groove wallet with its leather accessory (I think it's called the Groove wallet GO) holds the key card perfectly. You can also use the GO without the actual groove wallet by sticking it on your phone.
2024 Tacoma Toyota Key Card Sleeve - What Are You Using to Carry it? 20250712_104453
2024 Tacoma Toyota Key Card Sleeve - What Are You Using to Carry it? 20250712_104449
2024 Tacoma Toyota Key Card Sleeve - What Are You Using to Carry it? 20250712_104504
EastonTaco
Venice FL & Easton PA
I do the exact same thing. I tried inside the wallet but the RFID blocked the signal.
I love the Code 118 wallet. I added their leather sleeve which adds two more card slots, one of which is perfect for the key card. The leather sleeve also gives it a nice feel without adding any noticeable thickness.
