Upper control arm rubbing.
exia
los angeles
24 tacoma hybrid Trd OR
My 24 Hybrid off-road just got new suspension, and I noticed it might be rubbing on the upper control arm.
Any thoughts or fixes, anyone?
Is this a line issue, a UCA clearance issue, or did it rub when I lifted it on a jack to rotate the wheels?
I marked it in yellow to see if it continues to rub.
2024 Tacoma Upper control arm rubbing. IMG_6050
2024 Tacoma Upper control arm rubbing. IMG_6049
2024 Tacoma Upper control arm rubbing. IMG_6047
2024 Tacoma Upper control arm rubbing. IMG_6046
co425
Brandon
BMW Motorcycle
Looks like you may need to turn that shock reservoir down to rotate hydraulic elbow in to move the line away from the control arm.
exia
exia
los angeles
Looks like you may need to turn that shock reservoir down to rotate the hydraulic elbow in to move the line away from the control arm.
I see. Could this be done on my own? Or recommend going to a shop
co425
Brandon
BMW Motorcycle
I’m not trying to be rude. But.. if you have to ask that question you’re probably better off taking it to the shop that installed it.
exia
exia
los angeles
I’m not trying to be rude. But... if you have to ask that question, you’re probably better off taking it to the shop that installed it.
Your good 😂.
Just asking, as Ive never loosened a fitting under pressure, is all. Don't know how many turns before I eat turd.
co425
Brandon
BMW Motorcycle
NO NO NO! Not the fitting. The body of the reservoir. They rotate in the mount.
exia
exia
los angeles
That's what you meant. Yes, I tried it today and need to test.
exia
exia
los angeles
Okay. Cool. You don’t want to loosen those fittings. Good luck.
After clocking the external reservoir I have no success any other ideas you may have ?
2024 Tacoma Upper control arm rubbing. IMG_6078
2024 Tacoma Upper control arm rubbing. IMG_6074
2024 Tacoma Upper control arm rubbing. IMG_6077
2024 Tacoma Upper control arm rubbing. IMG_6076
exia
exia
los angeles
Does anybody think this is an alignment issue?
co425
Brandon
BMW Motorcycle
I’d say rotate that line closer to the spring. But I’m betting that line is under pressure. I’d be real tempted to take it back to the installer at this point.
exia
exia
los angeles
Ive gone to a shop that suggested extending the control arms for more clearance. They now clear by 0.90 mm; is that enough?
2024 Tacoma Upper control arm rubbing. IMG_6137
2024 Tacoma Upper control arm rubbing. IMG_6135
co425
Brandon
BMW Motorcycle
As long as you have full travel and no rubbing I’d say your successful.
