Wiring 3rd brake light
Greatisland
Victoria bc
www.instagram.com
2024 Tacoma offroad
Hey guys,
I picked up an alucab for my 2024 Tacoma off-road premium.
I wired in the 3rd brake light to the left hand side tail light. It operates great when I brake, but when I signal left the rear brake light also flashes. From the looks of it I need to tap a wire before the turn signal signal goes out. Does anyone know a better location to tap into?
I looked at using the trailer wiring but ran into the same issue.
Thanks!
Pfa
@greatislandadventures on instagram if you wanna see the interior build out as it progresses and some offroading content soon!
2024 Tacoma Wiring 3rd brake light IMG_20240625_174005
Tycoma
Ty
Oro Medonte
2024 TRD Sport Premium
Hey guys,
Thanks!
Pfa
Were you able to come up with a solution?
Utah
2025 Toyota Tacoma
I Ordered this and will update if it works. Hope it is that easy!
Not sure where to install this as it needs a signal from each turn signal (left [white wire] and right [different color] - to the 2 yellow wires on the logic module - one each). I believe the logic is if it only gets a signal from one it does not send the signal on to the 3rd brake light (Green wire on the logic module). If it gets a signal from both it sends it to the green wire up to the 3rd brake light.
