Your Tacoma Bed Doesn’t Need More Space—It Needs a Second Floor
TRUMGETA
CHINA
A Tacoma bed feels surprisingly large right up until you start packing for a camping trip.
First goes the cooler. Then the storage bins, camp chairs, recovery gear, water, cooking equipment, and the tent that somehow occupies twice as much space after you fold it.
Five minutes later, the bed looks less like an organized adventure setup and more like someone lost a game of outdoor-equipment Tetris.
That is where a truck bed rack starts to make sense.
The basic idea is simple: move bulky equipment upward, preserve the usable bed below, and stop making the cooler support half the campsite.
Trumgeta currently offers two adjustable rack approaches for owners who want to turn their truck bed into a more practical camping and hauling system: the Trumgeta Adjustable Truck Bed Rack for Tacoma and the Trumgeta 800 LBS Adjustable Truck Bed Rack for Mid/Full-Size Pickups—Worksite to Weekend Ready.
They solve a similar problem, but they do it in slightly different ways.
The Camping Value: Carry More Without Burying Everything
A properly configured bed rack creates two usable cargo zones.
The upper level can carry a rooftop tent, kayak, cargo box, recovery equipment, or other oversized gear. The bed remains available for coolers, food, water, tools, storage bins, and the items you actually need to reach during the trip.
That separation matters more than it sounds.
Without a rack, getting to one small item can require moving three large items first. With equipment mounted above the bed, camp setup becomes less of an excavation project.
It also gives owners more freedom to organize the truck by function:
  • Sleeping equipment above the bed
  • Food and cooking supplies near the tailgate
  • Recovery gear mounted where it can be reached quickly
  • Wet or dirty equipment kept away from clean camping supplies
The result is not just more carrying capacity. It is a campsite that takes less time to build and considerably less patience to pack back up.
This version is designed for Tacoma applications equipped with bed rails. Its adjustable frame can carry rooftop tents, kayaks, cargo boxes, spare tires, LED light bars, and other outdoor equipment while leaving the bed available for lower cargo. The product is sold as the rack structure; the upper platform shown in some setups is not included.
One of its more useful camping features is the side accessory-panel area.
Instead of placing traction boards, tools, lights, or smaller recovery equipment inside the bed, owners can use the sides of the rack as dedicated mounting space. That keeps frequently used equipment accessible without allowing it to compete with the cooler for valuable floor space.
The rack is adjustable in length, width, and height. For midsize-truck configurations, the listed adjustment ranges are approximately 35.4–48 inches in length, 41.4–62.8 inches in width, with three height choices of 18.8, 22.5, and 25 inches.
Those height options give the setup some flexibility.
A lower position can produce a more compact profile, while a taller setting can provide additional bed access and clearance for larger cargo. The right choice depends on the tent, tonneau cover, equipment, and how often the owner plans to reach underneath the rack.
The frame uses high-strength metal construction with corrosion-resistant materials intended for outdoor use. Trumgeta lists a 600-pound static rating, a 300-pound dynamic rating, and up to 66 pounds of capacity on each side accessory panel for this configuration.
In practical terms, it is a good match for the camper who wants the rack to serve as both an upper cargo carrier and a modular gear wall.
Trumgeta 800 LBS Adjustable Truck Bed Rack—Worksite to Weekend Ready
The Worksite to Weekend Ready rack takes a cleaner, more modular approach.
It uses an aluminum-alloy structure, offers versions with or without side bars, and includes integrated T-slot channels for attaching accessories such as lights, MOLLE panels, and tool holders.
The optional side bars are useful for owners building a more complete overland setup. They add mounting locations for equipment that would otherwise live in the bed.
Owners who mostly carry kayaks, ladders, or a rooftop tent may prefer the simpler version without side bars. That keeps the rack visually cleaner and avoids paying for mounting space they may never use.
This is a small but important value point: the rack can be configured around the actual use of the truck rather than forcing every owner into the same setup.
The rack provides four height settings between 19 and 25 inches, making it easier to adapt the structure to different loads and camping arrangements. The clamp-on installation does not require drilling into the truck bed, so the system can be installed without making permanent modifications.
That matters for owners who lease their trucks, regularly change their setups, or simply prefer not to introduce a drill bit to a relatively new Tacoma.
The aluminum construction helps balance strength with manageable weight, while its corrosion resistance is valuable for trucks that regularly encounter rain, mud, snow, road salt, or damp camping equipment. Wind-reducing silicone strips are also included to help limit rack noise during highway driving.
In other words, the rack is intended to carry gear—not perform a roof-mounted percussion solo at 70 mph.
From Weekday Truck to Weekend Basecamp
A good bed rack should not make the Tacoma useful only on camping weekends.
During the week, the same structure can carry ladders, lumber, tools, long materials, or jobsite equipment. On Friday afternoon, the work gear can come off and the kayak, tent, or cargo box can go on.
That ability to switch roles is where much of the value comes from.
Instead of installing a camping-only system that spends most of the month doing nothing, an adjustable rack can support:
  • Rooftop tents and awnings
  • Kayaks, paddleboards, and canoes
  • Cargo boxes and camping bins
  • Ladders and long work materials
  • Recovery boards and trail equipment
  • Tool holders and auxiliary lighting
  • Spare tires and oversized outdoor gear
Both rack families are intended to expand the Tacoma’s carrying capacity without permanently consuming the bed below.
The Tonneau-Cover Question
This is the part worth checking carefully before ordering.
Rack fitment depends on the truck’s bed-rail system and tonneau-cover design. Some configurations are intended for factory bed rails, while others work with compatible T-slot retractable or roll-up covers. Tri-fold covers are not universally compatible.
Before choosing a rack, confirm:
  • Whether the Tacoma has factory bed rails
  • Whether a tonneau cover is installed
  • Whether that cover has usable T-slot rails
  • The bed width and mounting-point spacing
  • The required clearance for a rooftop tent or other cargo
A tape measure used before ordering is considerably cheaper than a rack-shaped misunderstanding delivered to the driveway.
A Note About Load Ratings
The exact load rating can vary by rack configuration, vehicle, mounting system, and whether the truck is moving or parked.
The current product information also presents different capacity figures in certain sections of the Worksite to Weekend Ready rack listing. Anyone planning to mount a rooftop tent or other heavy equipment should confirm the rating for the exact Tacoma configuration and follow the lowest applicable limit.
Static capacity applies while the truck is parked. Dynamic capacity applies while driving and is generally lower because the rack must deal with braking, cornering, vibration, and trail impacts.
The tent may be rated for four adults. That does not automatically mean the rack wants to meet all four of them while the Tacoma is moving.
Which Setup Makes More Sense?
The Trumgeta Adjustable Truck Bed Rack for Tacoma is the stronger choice for owners who want integrated side storage, wide dimensional adjustment, and a rack that acts as both a cargo carrier and an equipment-mounting system.
The Trumgeta 800 LBS Adjustable Truck Bed Rack—Worksite to Weekend Ready makes more sense for owners who prefer aluminum construction, four-level height adjustment, T-slot customization, optional side bars, and a straightforward clamp-on installation.
Neither approach is automatically better.
The right rack depends on what the Tacoma carries, how the bed is currently configured, and whether the owner wants a minimalist crossbar setup or a more complete modular camp system.
The most useful rack is not necessarily the one with the most metal.
It is the one that keeps the tent secure, the bed usable, and the coffee equipment somewhere you can find it before sunrise.
Let’s See How You Would Build It
What would you mount first on a Tacoma bed rack: a rooftop tent, kayak, cargo box, traction boards, camp lighting, or something completely different?
Share your setup idea, camping experience, photos, or practical questions in the comments.
We will select one eligible, highly engaged participant to receive a complete Trumgeta 800 LBS Adjustable Truck Bed Rack—Worksite to Weekend Ready.
To keep the discussion useful, the selection will be based on thoughtful and constructive participation—not simply who posts the most comments.
Apparently, having strong opinions about Tacoma camping setups may finally pay off.
TRUMGETA
TRUMGETA
CHINA
Not compatible with OEM tonneau bed cover.​
Thank you for pointing that out. None of our current rack models are confirmed compatible with the Toyota OEM hard tonneau cover.
https://www.trumgeta.com/collections/truck-bed-rack
The compatible options—C1570V07-mid, C1918V07-mid, C1918V07, C1918V03, C1902, and C1998V02—require a compatible tonneau cover with exposed T-slot rails. We’ll update the post to make that distinction clearer.
