Mabett
LA
www.facebook.com
2026 Tacoma TRD Sport
Hi everyone, Jeremy from Mabett here. :fistbump:
Our new Mabett LED Grille Lights are officially available! This 4-piece set features enlarged lenses for a more integrated grille look, with no cutting or splicing of factory wiring required.
Fitment
Designed for 2024–2026 Toyota Tacoma in the following trims. Please also compare your truck's grille pattern with our fitment photos before ordering. Model year and trim alone do not guarantee compatibility.
  • TRD Sport
  • TRD Off-Road
  • TRD PreRunner
What Makes Our Grille Lights Different?
1. Enlarged Lens Face for a Closer Fit
We've designed a larger lens face that fills more of each matching grille opening, minimizing visible gaps for a cleaner, more integrated appearance.
2. Plug-and-Play Installation, No Drilling or Wire Splicing
Our grille lights come with a dedicated plug-and-play wiring harness. No drilling, cutting, or splicing of factory wiring is required.
Simply route the harness behind the grille, plug in all four lights, and snap them into place. Then connect the power lead to a switched power source in the factory fuse box using the included connector, and secure the ground wire to a suitable grounding point.
3. One-Year Warranty
We stand behind our products with a 1-year warranty. If you experience any quality-related issues within the first year, feel free to contact us for after-sales support.
Tacoma4G Launch Offer💥
Final Price: $25.99
Enter the promo code 4FOXLL66 at checkout to apply the discount.
Product Link: https://amzn.to/3V9lNdU
Questions or Feedback?
What do you think of the new grille-light design? Share your thoughts below. If you have any questions about fitment or installation, we're happy to help!
Get an extra 10% OFF when you join the Mabett 4th Gen Tacoma Garage. You'll also get access to early product updates, exclusive member offers, and selected product testing opportunities.
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
I like ‘em! Am in the Pro-Raptor Light camp regardless of whether it’s a Ford.
Mabett
Mabett
LA
www.facebook.com
Mabett
Mabett
LA
www.facebook.com
Mabett
Mabett
LA
www.facebook.com
These things couldn't be easier to install. The whole install took about 15 minutes and that's only because I was taking my time. They look incredible!
Look good bro!
dante116
Don
Sacramento, CA
Fitment
  • TRD Sport
  • TRD Off-Road
  • TRD PreRunner
Final Price: $25.99
Installed these. They look great! Some of the cabling is visible through the grill louvres, but it doesn't interfere with the active shutters and it's black cabling, so minimally visible, anyway.
Mabett
Mabett
LA
www.facebook.com
Thanks for sharing this.
Will721
Will
Quad Cities
2025 TRD OR
I installed a set of lights myself, not mabett brand tho. Anyway, a quick tip if you pull the front end for any other mods; black hot glue works perfectly to semi-permanently secure and hide the wiring. I pressed the wires into the natural contours of the grille from the back and hot glued them in place.
Mabett
Mabett
LA
www.facebook.com
:thumbsup::thumbsup:
nicholai
Toyota Tacoma
I assume these will not work on a Trailhunter? I never considered whether the hole pattern is different.
Mabett
Mabett
LA
www.facebook.com
Correct. The grille lights do not fit your trailhunter.
Will721
Will
Quad Cities
2025 TRD OR
Tacoma Lifestyle has a set that works. None of the push in style lights work with the trailhunter. It has to be the backing plate style, which requires pulling the front end btw.
