559Taco
New Taco
Fresno
2025 Tacoma
Materials (all from Home Depot)
3 × Simpson Strong-Tie A66 brackets (about $5 each)
M6 × 1.0 bolts (for truck mounting points)
M8 × 1.25 bolts (for compressor base, short length ~16mm)
Washers and lock nuts as needed
1. Prepare the Brackets
Take the Simpson A66 brackets and trim them where needed with a cutoff wheel.
Drill new holes to line up with the ARB compressor base plate.
Keep the off-cut piece — you’ll reuse it to mount the manifold later.
2. Build the Mounting Base
Use two A66 brackets to bolt into the Tacoma’s existing M6 mounting points near the fuse box.
These create the vertical “legs” of the mount.
The third A66 on side of fuse box as a support rail. The compressor wiggled a little with only 2 brackets so i added a 3rd from the other side
3. Attach the ARB Compressor
Bolt the ARB compressor’s factory mount plate directly to your bracket setup with M8 bolts. I had to drill a whole on the arb mount plate.
4. Mount the Manifold
Reuse the cutoff scrap from one of the A66 brackets.
Drill it to accept the manifold bolts.
Mount it to the bracket assembly next to the compressor for a clean, accessible location.
Manifold is tucked neatly above.
No welding or custom fab needed — just cutting, drilling, and bolting.
2024 Tacoma ARB dual brushless compressor DIY underhood mount on 2025 SR5 Tacoma PXL_20250828_153914822.MP
2024 Tacoma ARB dual brushless compressor DIY underhood mount on 2025 SR5 Tacoma Screenshot_20250828-214255
2024 Tacoma ARB dual brushless compressor DIY underhood mount on 2025 SR5 Tacoma PXL_20250828_160840095
2024 Tacoma ARB dual brushless compressor DIY underhood mount on 2025 SR5 Tacoma PXL_20250828_161853964
2024 Tacoma ARB dual brushless compressor DIY underhood mount on 2025 SR5 Tacoma PXL_20250828_183332655
2024 Tacoma ARB dual brushless compressor DIY underhood mount on 2025 SR5 Tacoma PXL_20250828_191416116
2024 Tacoma ARB dual brushless compressor DIY underhood mount on 2025 SR5 Tacoma PXL_20250828_192126261
2024 Tacoma ARB dual brushless compressor DIY underhood mount on 2025 SR5 Tacoma PXL_20250828_192131802
2024 Tacoma ARB dual brushless compressor DIY underhood mount on 2025 SR5 Tacoma PXL_20250829_204018818
2024 Tacoma ARB dual brushless compressor DIY underhood mount on 2025 SR5 Tacoma PXL_20250828_192123408
ixo
Rich
Antioch, CA
2024 Hybrid Tacoma OR Premium
looks good. I'm apparently the only guy on the planet with a fully separate compressor that I just clip to battery terminals when time to use <3
559Taco
New Taco
Fresno
2025 Tacoma
I've been doing the same but i want to get some air rear differential lockers so i needed a wired in compressor.
Rubenc87
Ruben
2025 TRD PRO
How does the final install look now?
Rubenc87
Ruben
2025 TRD PRO
I have the air chuck on a hose for now. Still deciding the final location and setup.
Looks good. Depending on where you are placing the chuck, the line might be too long.
