zekesview
Zeke
Walnut Creek, Ca
www.zekesview.com
2025 Toyota Tacoma TDR Pro
After a few months of working with C4 on version 2 of their rear bumper, I finally got it installed.
This is a direct OEM bolt on but if you have a TRD Pro trim, there are a few tweaks that you'll need to work through. Specifically the parking sensors along with the key fob sensor.
Open items include...
  1. Finishing mounting my Diode Dynamic C2R lights into the flush mount section - currently bolted to the frame
  2. Replacing the ARB Tow Hooks with C4 (which sit higher)
  3. Finding my rivnut tool so I can apply the step plates
The ARB Bumper along with the ARB Tow Hooks will be posted for sale shortly once I figure out a price. I also pulled off the TRD Exhaust and added a dump pipe just before the rear axle.
I also have C4 Rock Sliders and C4 Low Pro Front Bumper.
Overall I'm very happy with how this looks. The lines are clean and the build quality is top.
bsquaredMTB
El Paso, TX
Out of curiosity, is there any reason you mounted those lights below the high lift jack point instead of directly on the bumper? Or is that a future update?
zekesview
zekesview
Zeke
Walnut Creek, Ca
www.zekesview.com
I don't have or use a high-lift jack so that spot was safe for now. With the new C4 Bumper, Im going to flush mount them into the bumper (just waiting on the flush kit)
Ironically - Im getting a high lift soon so the timing is appropriate.
bsquaredMTB
El Paso, TX
Makes sense. I kept asking myself why would he have those holes in the high clearance bumper and have those lights mounted lower :ROFLMAO:
TexasBlueCrush
Tex
4th gen TRD Sport 6MT before that 3rd/2nd gen TRD Sport 6MT
That ARB tow hook you have in the trailer hitch tube is awesome.
1. Where did ya get it and how much ?
2. Are you using the trailer hitch pin that came in our Gove box or is that a regular AutoZone pin ?
zekesview
zekesview
Zeke
Walnut Creek, Ca
www.zekesview.com
That’s from Agency6 (think they’re right about $100) and I’m using a lock bought from Amazon.
Will721
Will
Quad Cities
2025 TRD OR
There are a ton of options, cheaper and more expensive, for hitch mounted recovery hooks. Personally I prefer this style:
Reason being the shackle allows for loop style recovery ropes without a secondary soft shackles. Just a little more versatile and cheaper. Could get a red shackle if you want it to match
Also really dig that bumper. Are the little pockets on the corner for more lighting as well or do they serve an alternate purpose?
zekesview
zekesview
Zeke
Walnut Creek, Ca
www.zekesview.com
The pockets on the corners are for the BSM Sensors (BlindSpotMonitor)
zekesview
zekesview
Zeke
Walnut Creek, Ca
www.zekesview.com
Update: Finished the install over the weekend.
C4 Tow Hooks installed and @Diode Dynamics C2R lights are now flush mounted.
Part Numbers for the Sensors:
89348-78120-C2 (2)
89348-70030-C1 (2)
Overall very happy with how this turned out.
P
25SilverTaco
San Jose
2025 Tacoma TRD Off-Road
That looks great! Got more pics from the rear and top showing cover plates? Also how did you wire the diodes?
zekesview
zekesview
Zeke
Walnut Creek, Ca
www.zekesview.com
I'll post some later today or tomorrow.
The Diodes are wired into the trailer harness. This is their reverse/running lights that tie super easily into the trailer pin
Diode Dynamics
John C.
St. Louis, Missouri
2021 Toyota Tacoma
C4 Tow Hooks installed and @Diode Dynamics CR2s are now flush mounted.
89348-78120-C2 (2)
89348-70030-C1 (2)
P
We love to see it! Great to see our flush mount C2R LED Pods gaining the traction they deserve.
JohnSadler
Moore, OK
Toyota Tacoma TRD Off Road iForceMax Premium
Did you install your rock sliders yet? If so, how was that install? I saw you mention needing a rivnut tool for the steps?
zekesview
zekesview
Zeke
Walnut Creek, Ca
www.zekesview.com
rivnut tool is for the rear bumper. Side Steps were very easy once I got my system down - doing it solo.
Show that here...
