QTac4
Shawn
Orlando
2024 Tacoma Limited Hybrid
In the great dechroming of my Limited, I found a spectacular local deal on a set of 2023 Tundra takeoffs ($500 for wheels/tires; prior owner had bought these for a 3G Tacoma and found they didn't fit). The big question: do they fit our 4G? It's surprisingly hard to find definitive information on this question. After a bit of research, it appeared they would probably fit, but I couldn't find anything here on Tacoma4G from anyone that took the plunge.
Given the price, I figured it was no-lose on my end. Just mounted them up this morning, and the fit is identical. Same offset, same bore, same BCD. Stock lug nuts tightened the same number of turns (about 8-9). As far as I can tell, they also have the same offsets and are positioned in the wheel wells same as stock.
So, 2022+ Tundra wheels fit our 4Gs. These are 20" Tundra wheels, and rolling diameter is about 1" larger. Will give a 2mph error in speed at 65, but I can live with that. Personally, I think the dechromed Limited is better looking.
Looks great!
Considering the same wheels machined finish gray
QTac4
Shawn
Orlando
I’m also going to do this with my Limited, I bought a set of 20” Tundra wheels and I’m waiting for Tire Rack to deliver my tires. I’ve noticed these Tundra wheels are about 10 pounds heavier each , have you noticed any acceleration loss ?
Good day Dave, what wheels are you running with yours? Look good
Daveintb
Tampa
I’ve got the 22 up Tundra wheels on mine as well.
QTac4
Shawn
Orlando
Got the Tundra wheels installed.
2024 Tacoma CONFIRMED: 2022+ Tundra wheels DO fit the 2024+ Tacoma 4th Gen IMG_7348
htioki
So Cal
2026 SR5 DCLB 2WD
I have been looking into this upgrade for my 2WD SR5. The 20" tundra wheels/tires are roughly 20 lbs heavier and 2" larger overall diameter than the stock SR5 wheels/tires. Would appreciate feedback on acceleration (more sluggish?), braking (longer distance?) and mpg (how much less).
