- First Name
- Jake
- Joined
- Feb 8, 2024
- Threads
- 15
- Messages
- 140
- Reaction score
- 139
- Location
- Fort Worth, Texas
- Vehicle(s)
- 4th Gen Tacoma
Welcome
Cali Raised LED
www.CaliRaisedled.com
Phone: 888-385-5036 l Email: [email protected] l Instagram: @cali_raised_led
https://caliraisedled.com/collections/2024-toyota-tacoma-oem-switches
Toyota gave us factory AUX switches in the 2024 Tacoma, but figuring out how to actually wire them up isn’t super clear. We put together a quick how-to video showing how to tap into the OEM wiring safely, without cutting into anything.Cali Raised LED
This is for trucks with the built-in AUX panel (usually part of the Tow Package). If you’re looking to run ditch lights, a bed compressor, or any 12V gear using those switches, this walk-through shows where the wires are, how to connect, and what you need.
What we cover in the video:
- Locating the AUX relay/fuse block under the hood
- Identifying AUX 1–6 outputs
- What connectors and fuses are needed
- Best practices for clean routing and safe connections
Let us know if this helped—or if you have questions we didn’t cover in the video.
Install Video
Aux & Switch Install Video
