How to Use Factory AUX Harness in 2024 Tacoma SR5 4x4 (No Pigtails or AUX Buttons, No Firewall Wiring Needed)?
patriotgiants
2024 Tacoma SR5
Hey everyone,
I have a 2024 Tacoma SR5 4x4 that came with the factory auxiliary harness (Locations A & B), but it did not include pigtails or factory-installed AUX buttons. Since the harness is already installed, I want to figure out how to use it without running additional wiring through the firewall.
What I Know So Far:
Location A (Engine Bay) has power and is designed for connecting accessories.
Location B (Cabin - Behind Trim Panel) is also powered, capped from the factory, and can be used for switches.
I do not have factory AUX buttons, so I need to figure out how to control these circuits using the existing harness.
What I Need Help With:
1. How do I properly connect accessories (like ditch lights) using only the existing harness?
2. How do I control the circuits without factory AUX buttons?
3. For anyone with the factory AUX buttons installed:
Can you share a picture of your switch panel so I can see what it looks like? does it directly connect to Location B, or is there another module in between?
Goal:
I want to use the factory harness as Toyota intended, without running new wires through the firewall. Any help, wiring diagrams, or photos would be greatly appreciated!
Thanks in advance!
2024 Tacoma How to Use Factory AUX Harness in 2024 Tacoma SR5 4x4 (No Pigtails or AUX Buttons, No Firewall Wiring Needed)? IMG_3324
2024 Tacoma How to Use Factory AUX Harness in 2024 Tacoma SR5 4x4 (No Pigtails or AUX Buttons, No Firewall Wiring Needed)? IMG_3093
Brian2011
MASS
2024 Trail hunter
I would assume there is a connector right where the aux switch panel would go as it came from the factory or somewhere in that area of the panel that needs to pop out. you might be able to order the panel and the switches from Toyota along with the pigtails, I would not look to splice anything on the truck at all.
2024 Tacoma How to Use Factory AUX Harness in 2024 Tacoma SR5 4x4 (No Pigtails or AUX Buttons, No Firewall Wiring Needed)? 1738959538586-cy
cali raised has OEM factory switches that will fit into your blanks, see this thread here for more insight on the relays and fuse panels. Trucks without factory aux switches | 2024 Tacoma Forum (4th Gen) News, Specs, Models - 2.4L, Hybrid, TRD Pro, Trailhunter, Off-Road, Sport, SR5 -- Tacoma4G.com
patriotgiants
2024 Tacoma SR5
This is what the back of the panel looks like for me. Any chance you see the wiring needed from the picture?
2024 Tacoma How to Use Factory AUX Harness in 2024 Tacoma SR5 4x4 (No Pigtails or AUX Buttons, No Firewall Wiring Needed)? IMG_3328
2024 Tacoma How to Use Factory AUX Harness in 2024 Tacoma SR5 4x4 (No Pigtails or AUX Buttons, No Firewall Wiring Needed)? IMG_3329
Brian2011
MASS
2024 Trail hunter
You’ll need more than just the wiring in place. You will need to ensure the fuses and relays are all in place. .
varography
Alvaro
Long Beach, CA
2024 Tacoma SR5 4x4
Hey everyone,
What I Know So Far:
Goal:
Thanks in advance!
YESSS I WAS JUST COMING TO THIS CONCLUSION AS WELL!!!
patriotgiants
2024 Tacoma SR5
My fuse box has spots for the AUX, but the fuses are not there. On the trims that are not a 4 x 4, that harness is not there and they don’t have the spots in the fuse box for it.
So Toyota must have made it possible for us to be able to utilize that somehow.
Delta1Seven
Curious if you solved this.
patriotgiants
2024 Tacoma SR5
no I have not haha. It’s still a mystery to me why would they include the harness but not a way to add aux switches.
