Fox 2.5 Performance Elite Coil Overs with Ark Splash Guards installed
DTG1712
Darren
Sandia Park, NM
2024 TRD OR Hybrid
Anyone, who has installed Fox 2.5 coil overs w reservoirs might be happy to know the Ark Splash guards will work with them. They will just need a little modification. I first placed the splash guards in place as best I could. I then marked it with a sharpie in the areas that needed trimming. I then took my time and used a narrow diameter Dremel bit to do my rough cutting. I fit and cut several times until I achieved clearance as needed. I then cleaned up the cuts using a fine cut carbide Dremel bit on slow speed. Finally, I used a heat gun to make it look as clean as possible. Im sure the Ark Splash guards will work with the King 2.5's as well. This mod will help protect the remote reservoirs while still allowing access to adjust your DSC adjustors.
2024 Tacoma Fox 2.5 Performance Elite Coil Overs with Ark Splash Guards installed IMG_1848.JPG
2024 Tacoma Fox 2.5 Performance Elite Coil Overs with Ark Splash Guards installed IMG_1850.JPG
2024 Tacoma Fox 2.5 Performance Elite Coil Overs with Ark Splash Guards installed IMG_1761.JPG
bigd9247
Dalton
2024 TRD ORP, 2018 F150 XLT
How do you like the Fox suspension? Also, what upper control arms are you running?
DTG1712
DTG1712
Darren
Sandia Park, NM
2024 TRD OR Hybrid
So far I am really liking them. I only have approximately 500 miles on them so far, so I definitely need a few more miles on them to properly review them. So far on road at factory settings of 4 high speed and 4 low speed, they feel very similar to the factory Bilstein's. They are firm cornering and absorb average bumps in the road nicely. I have tried them out on a washboard road near our home. I set the high speed to 6 and low speed to 2. That was amazing at at 35 mph. I will try these same settings going up to our cabin in the summer. We have a 15 mile FR leading to our cabin with lots of washboarding and pot holes to navigate. It will be fun playing with the settings this summer to see what works best.
tkrum015
Ted
Olympia
Did you need a Diff. drop and longer front axles? Any strange noise or vibrations?
DTG1712
DTG1712
Darren
Sandia Park, NM
2024 TRD OR Hybrid
[/QUOTE
No, I did not use a diff drop. So far no strange noises, vibrations or issues to date.
bigd9247
Dalton
Now that it's been a few months, any more thoughts on the Fox shocks? I've been thinking about a set but they're spendy.
DTG1712
DTG1712
Darren
Sandia Park, NM
2024 TRD OR Hybrid
Initially, I thought they were a bit to stiff. Now that they have a few miles on them, I think they have a great balance in responsiveness to bumps with little to no body roll on cornering at higher speeds. Like you said, they are a bit pricey though.
tragisj
Alaska
Toyota Tacoma 24 OR, Toyota 4Runner 21 OR
Your Fox setup (including exclusion of the diff drop) are probably ideal to me. What lift level did you go up to front and rear?
I ordered Ray's Daytona wheels at 17x8 +20 and K03 tires at stock 265/70 R17. My goal is to essentially level the truck, add stance and get Fox PEs to improve ride quality. Looking for the sweet spot of front and rear to essentially go OEM+.
tkrum015
Ted
Olympia
Ditto above, looks great . Did you add any springs in the rear ? now that it’s had some time to settle how much lift did you get front and rear? Any before and after pics?
DTG1712
DTG1712
Darren
Sandia Park, NM
2024 TRD OR Hybrid
I ended up using the factory specs of 2.25'' of lift in the front and I did not add any springs in the rear. I have about .25'' of rake as it sits now. Unfortunately, I no longer have the measurements of before the coil overs to give you a comparison. Here are a couple of phots though.
2024 Tacoma Fox 2.5 Performance Elite Coil Overs with Ark Splash Guards installed IMG_1834
2024 Tacoma Fox 2.5 Performance Elite Coil Overs with Ark Splash Guards installed IMG_1495
2024 Tacoma Fox 2.5 Performance Elite Coil Overs with Ark Splash Guards installed IMG_2342
2024 Tacoma Fox 2.5 Performance Elite Coil Overs with Ark Splash Guards installed IMG_2343
RutsyBucket
Hunter
Carlsbad, CA
2025 Terra Off Road
That install is absurdly clean. It's probably very overkill, but looks great. Nicely done.
