What boats are you towing with a 2024 IForceMax Hybrid?
smacota1
JR
Ala
2019 Tacoma
I have a 2024 Limited and pull a 175 Pioneer BaySport with no problem. I am considering a new boat such as a 215 Scout FSX. This will weigh about 5800# with gear and full fuel. Just seeing what some of you are pulling with yours. Thanks
I don't have first hand boat towing yet, unfortunately. But Toyota has always been conservative in their tow ratings and I have always felt comfortable towing up close to them.
The hybrids have the power and weight to tow like a smaller Tundra, and that is a very good thing. I'll also be interested in hearing owners feedback on this.
I’ve got an old Marlin Eldorado 21ft its 6K loaded. I don’t have the hybrid and it tows it shockingly well.
2024 Tacoma What boats are you towing with a 2024 IForceMax Hybrid? IMG_5397
smacota1
JR
Ala
2019 Tacoma
MT Taco...... THanks
I got out of the boat hauling business a long time ago but do occasionally tow fully loaded dual axle open/closed uhaul trailers. With my Tundra it was an effortless affair and I would expect the Tacoma to be a worthy replacement.
I agree. I bought a Tundra to do that kind of towing, because my 2nd gen was just not up to the task. But 4th gens are based on the same structure as a Tundra and the hybrids have more torque than the 5.7L V8 in my Tundra, so they should tow very well.
After I posted above, I got curious and threw some specs into AI and had it run some numbers. Here are the results:
Off-Road and Towing Performance Comparisons: 2013 Tundra vs. 2024 Tacoma Hybrid
  1. Low-End Gearing (1st Gear * Final Drive Ratio)
    • 2013 Tundra: 16.81:1
    • 2024 Tacoma Hybrid: 17.24:1
    • Higher is better for off-road traction—Tacoma has a slight edge, making it better for low-speed crawling.
  2. Reverse Gearing (Reverse Gear * Final Drive)
    • 2024 Tacoma Hybrid: 14.27:1
    • Tundra has a stronger reverse gear, which could be helpful for backing up heavy loads or in off-road situations.
  3. Torque Multiplication in 1st Gear (lb-ft)
    • 2013 Tundra: 6,742 lb-ft
    • 2024 Tacoma Hybrid: 8,018 lb-ft
    • The Tacoma's hybrid system produces significantly more usable torque at low speeds, making it a better performer when towing or off-roading.
  4. Crawl Ratio (Higher is better for slow-speed traction)
    • Again, the Tacoma's gearing gives it a better ability to crawl over rough terrain with control.
Conclusion
  • Towing: Tacoma’s much higher torque multiplication (8,018 lb-ft vs. 6,742 lb-ft) gives it a clear advantage when pulling heavy loads from a stop or going uphill.
  • Off-Roading: Tacoma’s better crawl ratio and low-end gearing allow it to maintain better traction at slow speeds, making it superior for rock crawling.
  • Reverse Performance: The Tundra has a stronger reverse gearing ratio, which could help in tricky towing maneuvers.
