Can anyone identify this rattle?
korybeene
kory
virginia
2024 tacoma TRD off road
I don’t know what part is making this noise and the dealer didn’t even attempt to find it. It’s super annoying on the highway and rattles pretty loud over any bumps.
HBNARO
Scottsdale Az
2024 TRD PRO Terra
Sounds like you should not beat on the side mirror or it makes a rattling noise.
korybeene
kory
virginia
Thanks genius. It does it whenever I drive on any road too, it’s really annoying.
Have not seen this one before but at least you’ve narrowed it down to the side mirror assembly. I’ve got a rattle coming from somewhere around the passenger seatbelt area when I’m going over vertical bumps and I simply cannot find where it’s coming from. Seems like I will need to remove a trim piece to find it. Of course when I took it to the dealer I could not replicate it.
Xjim
Jim
Central Ohio
Check to make sure it isn’t the unfastened seat belt bumping the side column door frame.
mine did this too until I reached over and repositioned the dangling seat belt.
I tried that. It sounds like that but it’s something different. I’ve tried putting the seatbelt into the clip and even fastening it. I even added felt to the column.
korybeene
kory
virginia
Same here
korybeene
kory
virginia
I’m in college so I don’t have my tools, I want to rip the whole mirror assembly apart and cram it full of foam
Cabby30
CA
2024 DCLB TRD OR
OP, I've never opened a 4th gen mirror cap but my guess would be the electrical connector in there loose and clicking around
Solid advice - open it up - could be a loose harness - I once had a sedan that would rattle from the back brake light and it was a loose electrical harness .., had to drop the headliner to fix it
bking
Bernie
2024 Tacoma TRD Offroad
Rear seat belts were banging for me. There is a clip to hold them in place
