4th Gen Tacoma Aftermarket Lift Kits and Leveling Kits
jtgearhead
JT
Salt Lake City, UT
2023 Toyota Tundra
Darrin Carter
Buckshot
SAULT STE MARIE
2024 tacoma TRD sport premium
I will probably end up with the levelling kit
My sales rep said if they install it will not void factory warranty
Pretty easy looking install but might be worth having dealer do just to not screw up warranty
Newtacointown
Subaru
Ready Lift also has a 1.5 inch front levelling kit available now. Still no info on the Toyota TRD lift kit, what it comes with and how much it will cost. No other real suspension lift options. I can’t go with these spacer lifts or the Westcott preloaded collar lift because I have too much permanent weight in the back with a GFC. And 285/70/17 tires that I want look crammed in the wheel well with no lift :(
2ndGen2TrlHntr
Alex
Denver, CO
Ready Lift also has a 1.5 inch front levelling kit available now. Still no info on the Toyota TRD lift kit, what it comes with and how much it will cost. No other real suspension lift options. I can’t go with these spacer lifts or the Westcott preloaded collar lift because I have too much permanent weight in the back with a GFC. And 185/70/17 tires that I want look crammed in the wheel well with no lift :(
I’m assuming you meant 285x70x17? I have 285x70x17 now on my second gen but plan to go 35’s when I get my Trailhunter assuming it’s as easy to fit as I think it will be.
oxi
Pete
Wisconsin
2024 TRD Sport 6MT
Which is a better design?
Ready Lift or Rough Country?
garciava
Vic
Western Colorado
2024 Tacoma TRD Sport Long bed
I put the RC front 1.5” leveling kit on mine. Easy to install and looks good. I did have it aligned afterwards to insure it was good
Powhunter
Alberta
Peak Suspension had a couple different options as well for levelling and suspension kits. I don’t think they’re in stock yet though.
BlackTaco
BlackTaco
2024 Taco OR
Now that the trucks are hitting lots and manufacturers are starting to release products, curious to see what everyone is going with.
Options out for now, I'll update this as more options become available:
Leveling Kit:
Rough Country 1.5" Front Leveling Kit (looks to be in stock)
ReadyLift 1.5" Leveling Kit
Lift Kits
Westcott 2.5" / .75" Lift Kit (Pre-order for march)
I got below link from a Lift professional, saying that leveling are notorious for putting abnormal angles on your front end and cause premature wear to suspension and drive train.
https://accutuneoffroad.com/articles/spacer-lift-vs-preload-spacer-vs-coilover-preload/
Levelling or not ?
kefferjoe
Joseph
Tempe, AZ
2024 TRD Sport Premium
Peak Suspension
Nick
Riverside
2024 Toyota Tacoma TRD Offroad
Levelling or not ?
That all depends on how the spacers or lifts are installed. Historically, lift spacers push a lot of forces down on the shocks, and in previous generations with the Bilstein shocks having such a thin stem, it could bend or break the lower shock stem.
Our kits are a 2 piece design so that the lift is spread from a small top spacer and a small spring adapter.
There's no doubt that coilovers are a better option, but that's not in everyone's budget unfortunately
Luke
IRONMAN 4X4
ironman4x4america.com
F150, Land Cruiser
Devildog81
minnesota
2024 tacoma trd offroad
I’ve been running the Peak Suspension 1.25” leveling spacer for about a month now. Truck drives and rides great.
2024 Tacoma 4th Gen Tacoma Aftermarket Lift Kits and Leveling Kits IMG_5523
Mini2nut
I had the $500 Westcott kit for about a month. I was not happy with the ride and had it removed.
I bit the bullet and had a complete set of front and rear King 2.5 shocks and sway bar links installed. The shock upgrade made a night and day difference in the ride. Buy once, cry once.
2024 Tacoma 4th Gen Tacoma Aftermarket Lift Kits and Leveling Kits IMG_2353
2024 Tacoma 4th Gen Tacoma Aftermarket Lift Kits and Leveling Kits IMG_2355
2024 Tacoma 4th Gen Tacoma Aftermarket Lift Kits and Leveling Kits IMG_2352
MERAKIAUTOWORKS
Joshua
Anaheim, CA
^ Awesome, I plan on doing the same.
-Josh
