Popping sound beneath rear of truck bed?
Tacorey
Corey
Atlanta, GA
2025 Tacoma TRD Offroad; 2007 Infiniti M35
I just got my truck and was walking around in the bed to check everything out. I noticed a popping noise coming from the truck bed, but wasn’t sure what it was. I checked the spare tire, it looks tight. I also looked beneath the truck to see if anything looks out of the ordinary, but I didn’t see anything other than a hole that “might” be missing a bolt but not sure.
I decided to walk around on it some more, and it seems like the only place it happens is near the tail gate in the center. It sounds to me like the bed is bowed up, me standing on it compresses it down, and the pop sound I'm hearing is from it unsticking from whatever is below after the weight is released. Is this normal? It’s similar to a hardwood or laminate floor where there’s a tight area that bows up a bit, and when you step on it, it makes a pop/unsticking noise after you remove your foot.
SDchrisC
CA
Tacoma TRD OR
I Thought I was the only one!! I Have this same exact issue and cant pinpoint where it coming from.. if you find out can you post it
Tacorey
Corey
Atlanta, GA
Will do. Might try to take it to the dealer this weekend. Do you have the spray in liner?
Tacorey
Corey
Atlanta, GA
No just the regular composite bed
Okay, mine came with the spray in, so doesn't seem like it's related to that. My guess is a bed alignment/bed binding issue. I will update when I get a chance to get it checked out.
Tacorey
Corey
Atlanta, GA
Any of you guys have a service coming up where you could ask them to look at it?
boyler
Jay
canada
2025 tacoma
I have the same noise on a 6ft bed. I crawled underneath and noticed, it looks like the bed just has a locating tab sticking through rear cross rail in that spot and possibly does not have a fastener or at least never has had a fastener. I'll mention it to the dealer during my first service
BAQ717
‘24 Tacoma TRD OR
I believe it’s just the bed liner bending and snapping against the composite bed. I don’t believe it’s truly a spray in liner that permanently bonds with the surface.
mr.moyogi
Joel
Salem OR
2025 Tacoma TRD Sport Premium
Guys, I've got the same issue. 5' bed with spray in bedliner. Opening a warranty claim. I feel fortunate that this issue is repeatable and easily demonstrated to a service technician.
BAQ717
‘24 Tacoma TRD OR
Let us know what they determine. I just figured it was the bed liner snapping against the bed.
Tacoyaki
Tacoma TRD Off-Road
Same issue, 6ft bed. Looking forward to hearing what the dealers tell you guys.
Reptar
Michigan
2025 Tacoma TRD OR LB
Same issue with my 2025 6ft bed.
Reptar
Michigan
Here's a picture and video from the underside.
Suzay
Hawaii
2024 Tacoma sport
Any updates on this? Mine makes similar noise but when truck is cool not in the sun initially on right turn. Doesn’t make noise on left turns. Once it makes that noise, just one time after making a right slow turn, that’s all I hear of it till next morning while still dark.
