Shark fin antenna relocate to inside dashboard
dougthescience
Doug
North Oregon Coast
2024 Tacoma Offroad
I needed to remove my shark fin antenna so a slide-in camper would have enough clearance above the roof. Here's some of the highlights of what I did:
First, drop the headliner near the rear window:
2024 Tacoma Shark fin antenna relocate to inside dashboard IMG_7603
Unlike past generations, the rear hangers don't twist to remove. You need to pop off the cover and then remove the metal clip that holds the hanger. Two small screwdrivers or spudgers will do the trick on the cover.
2024 Tacoma Shark fin antenna relocate to inside dashboard IMG_7604
Release the hanger from the metal clip. Needlenose pliers help.
2024 Tacoma Shark fin antenna relocate to inside dashboard IMG_7606
Here's the hard part. Lift the clip and squeeze so the bottom retaining portion of the clip is released from the square hole, and simultaneously use a small screwdriver to release the upper portion of the clip from the top.
2024 Tacoma Shark fin antenna relocate to inside dashboard IMG_7608
Here's what a removed clip looks like.
2024 Tacoma Shark fin antenna relocate to inside dashboard IMG_7610
Remove C-pillar covers on both sides for ease of access to antenna connector. The driver's side C-pillar covers the white connector that can be disconnected to make the process easier. Also, cut or remove the tape that holds the antenna harness to the edge of the headliner at the top of C-pillar.
Drop the rear portion of the headliner that is above the rear window so you can see the antenna harness/antenna connection.
Remove the 10mm bolt that holds the antenna harness to the roof above the rear window. This bolt appears to act as a ground for the harness as well. You will re-use this bolt later on when stashing the shark fin antenna in the dashboard, if that is where you choose to put the antenna.
If anyone is interested in camera removal or relocation, the grey connector next to the white connector is where the camera near the 3rd brake light camera connects.
2024 Tacoma Shark fin antenna relocate to inside dashboard IMG_7611
Remove the 10mm bolt holding the antenna harness to the bottom of the shark fin antenna. At this point you can remove the shark fin from the top side of the roof as well. Unclip the wiring harness between the antenna and white connector.
2024 Tacoma Shark fin antenna relocate to inside dashboard IMG_7615
Bottom view of shark fin antenna. Bolt is an M6 x 1.00 thread pitch.
2024 Tacoma Shark fin antenna relocate to inside dashboard IMG_7614
Hole in roof is approximately 20mm x 32mm rectangular hole.
2024 Tacoma Shark fin antenna relocate to inside dashboard IMG_7619
2024 Tacoma Shark fin antenna relocate to inside dashboard Screenshot 2025-03-23 at 13.01.08
I purchased these plastic plugs to cover the hole.
I had to shave off most of the ribs/fins to fit the plug into the hole using a box cutter. I then sanded the plastic surfaces that would be seeing the adhesive because the otherwise shiny surface doesn't allow for a great surface to adhere to.
2024 Tacoma Shark fin antenna relocate to inside dashboard IMG_7617
I taped off the roof about an 1/8" away from outline of the plastic plug, loaded the plug up with Sikaflex 291 and pushed the plug into the hole.
2024 Tacoma Shark fin antenna relocate to inside dashboard IMG_7618
Here's the final product. Not super pretty but it's held out a couple of North Oregon Coast deluges, so I'm happy. Plus my new Kimbo camper won't need a spacer below it to lift it above the shark fin.
Then, I removed the top of the driver's side B-pillar cover and released the headliner along the driver's side. That allowed me to pull off the glued-down antenna wiring harness that runs along the topside of the headliner near the driver's side edge of the headliner.
I removed the A-pillar cover and dashboard speaker cover and the speakers (tweeter and ~3" dashboard speaker). I kept the antenna harness bolted to the A-pillar (about 2/3 of the way down the pillar).
I then reconnected the white connector, connected the shark fin to the antenna harness, spooled up the harness and shoved the shark fin and harness through the dashboard speaker hole. Sorry, forgot to take a picture of this!
The fin fit just perfect in a section of the dashboard directly to towards the centerline of the dashboard behind the gauge cluster, and miraculously there was an unused threaded 10mm bolt in a metal piece that runs between the dashboard speaker location and the place where the shark fin was nestled. I used this to attach the harness bolt from the rear-roofline above the rear window.
Attach all pillar covers and drink a beer!
Reception isn't quite as good as before but for me the new out-of-the-way location is worth it.
2024 TRD Sport-Bronze oxide.
Is the shark fin just for satellite reception or does it also function for AM/FM and HD radio?
Sner
Seems like a ton of work, I know the aftermarket makes a low profile shark fin antenna for many different applications.
dougthescience
Doug
North Oregon Coast
2024 Tacoma Offroad
That's better than any I found, but it looks like about the same height as ours, except that the wiring to connectors is totally different.
I think when they say "low profile" they are talking about lower profile than a whip antenna.
dougthescience
Doug
North Oregon Coast
2024 Tacoma Offroad
I think it is an all purpose antenna for GPS, am/fm and HD radio and satellite radio.
dougthescience
Doug
North Oregon Coast
2024 Tacoma Offroad
I'm sure there's better ways to deal with the antenna if you don't have to completely make it disappear like I did. Just thought I'd post this for those that need to get it out of the way entirely.
h2o-bar
Western Slope
4Runner,Trailhunter
Great write up. I never thought about re-locating the antenna to the inside/dash of my truck. How about a pic of the final instal? I'll be looking to do the same since I also have a cab-over camper.
Dirt
Greg
Eastern OR
That's a heck of a project and mighty good write up with the pictures. A couple of questions - Did you have any problems re-attaching the head liner? Do I understand correctly that the antenna is now under the windshield glass and dash board amongst the other wiring back there? You kinda answered my concern about the last part - if you have pretty good reception on the N. OR coast that's pretty normal :giggle:
dougthescience
Doug
North Oregon Coast
2024 Tacoma Offroad
No problem reattaching headliner. It’s mostly just shoving the headliner edge back under the rubber door moldings.
The new location of the antenna is directly under the top surface of the dashboard, forward of the gauge cluster. No wires above it. Sort of a perfect place it seemed to me. So yeah, just the plastic dashboard and glass of the windshield above the antenna.
I’m probably not going to take the A-pillar cover and dash speaker cover off again just to take a pic of the wiring spooled up.
Or, if you were asking what the final install looks like from inside the vehicle, it looks just like before I did the relocate. Everything is internal to the A-pillar and dashboard.
Dirt
Greg
Eastern OR
Thanks, Doug. I really did not expect you to take all that apart to take another picture. Interesting write up for an unusual project. Thanks for answering my questions.
dougthescience
Doug
North Oregon Coast
2024 Tacoma Offroad
2024 Tacoma Shark fin antenna relocate to inside dashboard IMG_7636
Camper is on and works great! I did need to purchase 2 of Kimbos rubber mats to between the truck bed and camper instead of just one. The bed rails are tall enough that they were going to be connecting with the bolt heads of the jack stand supports.
Dirt
Greg
Eastern OR
Nice looking setup; classy with the color of your Tacoma.
