jhall757
Abingdon, VA
Recently lifted my 4th gen with the Eibach Stage 2 Pro Truck Lift and ran into a squatting issue with the rear shocks. The rear springs that come with the Stage 2 kit only give around 1" of lift. I ended up having to go purchase the "heavier" 2.2" springs to give a bit of rake. For reference, the springs that come with the kit are part # E30-82-105-01-02, and the replacement springs are part # E30-82-105-02-02. I adjusted the front shocks as low as they would go. After the new springs were put on, the truck is feeling great. Currently running RRW 17" wheels with a +25 offset and 315/70/17 Baja Boss A/T tires. Minimal rubbing in the front with no rubbing in the back. ***The first photo shown is with the original springs with the factory wheels/tires in the bed - also on a slight decline.***
reklov
@VentureOutTRD
Pacific Northwest, USA
2024 TRD OFF-Road Premium
Surprised you had to go with the heavier springs since you've got no weight in the rear. The E30-82-105-02-02 says it's for heavier payloads. I just got the kit as well. I guess we'll see how it is on my truck.
13cam13
texas
2024 tacoma
How many inches was the lowest setting on the front shocks?
jhall757
Abingdon, VA
Let me know how yours turns out! It seems like the front suspension has settled a bit after 4-500 miles - but I feel like it would be level at max for the softer rear springs.
