Delta1Seven
So a few weeks ago I went down the rabbit hole on how to re-calibrate my 360 cameras after I swapped my Limited Grill for a Heritage Grill.
To calibrate your cameras, it's actually fairly simple. You can do it all on your radio infotainment screen.
Steps to access the Calibration Menu (service menu):
1. Get in your truck and close all the doors and windows. From my testing, you cannot access the Service Menu if a door or window is open. Once you access the Service Menu, you then can open a door or window.
2. With your foot off the brake pedal, double click your stop/start button to access Accessory Mode
2. Wait until the infotainment (radio) screen boots up
3. Turn the volume all the way off
3. Go to Settings > Display > Screen > Turn off Display
4. Okay so here is the hardest part. You have to swipe left to right 5 times, and then right to left 5 times. Your screen may display "Touch to turn screen on" while you are swiping, but ignore the message.
4a. It may take 1 or 2 tries to get this to work. If you mess up, you just have to tap the screen to turn it back on, then turn it back off in the settings. Then continue with step #4 again.​
5. If swiped correctly, you should see a Service Menu pop up.
6. Navigate to Function Check > Camera Settings > View Adjustment
6a. If an option is greyed out, just hold the desired option for appx. 5 seconds and it will let you select it.​
7. After selecting View Adjustment, select Next.
8. You will now see the birds eye view of your truck where you can make adjustments.
9. After making your adjustments, select Ok.
10. Once it completes saving, click OK and you can exit the Service Menu. The next time you start the truck, it will ask you to complete service mode and just choose ok to complete.
Notes:
- Accessory Mode only stays on for 15-20 minutes, so make sure you don't take too long to adjust all your cameras otherwise you will have to restart the process.
- I don't think it's possible to get the cameras aligned 100% perfectly. I got it like 95% good and I was happy with the result
- While adjusting the cameras, where both cameras line up and meet in the image, there is no blending effect of how they mesh together. Once you exit the Service Menu, and start driving, the normal 360 camera view adds a blending effect to where the cameras mesh together to hide some of the imperfections of misalignment, so don't worry if the service menu doesn't look 100% perfect.
- If you are only looking to realign your front camera after swapping grills, you can follow the above steps (change the front camera angle to +165 should get you close to spot on, adjust + or - 1 until you get it perfect).
Be cautious when making changes in the Service Menu. It appears you can change other settings in this menu as well, and I recommend not doing so unless you know what you are doing. I am not an export and I am just sharing some of the information I have found.
If you are looking to do a full recalibration of all the cameras, I have attached the official Camera Calibration Procedure from the Service Manual that I found shared online. This procedure is very in depth, and honestly probably not recommend if you are only swapping your front grill camera (I believe other forum members were able to change their front camera calibration to +162 or +165 to get it adjusted correctly) With my tailgate camera also being misaligned from the factory, I performed this calibration to get everything dialed in. It did take some time, especially settings up all the tape.
The official calibration procedure of laying tape down in precise locations was time consuming and very tedious to get all the tape lined up perfectly. Honestly, I think if you just take a 2ft x 2ft piece of wood or cardboard, put some painters tape on it, and move it around to each corner of your truck where your cameras 'mesh' together in the view, it will work almost as good. I've saw someone else mentioned they just went to a parking lot and used the painted lines.
2024 Tacoma How to recalibrate your 360 Cameras 1744997174649-i8
Tape laid out per the Service Manual Procedure
2024 Tacoma How to recalibrate your 360 Cameras 1744997187680-wq
This was as close as perfect as I could get it. It's not perfect, but I was happy with the results. Much better than how it came from factory. The adjustment values in this picture are not accurate, as each time you save, the value returns to zero.
2024 Tacoma How to recalibrate your 360 Cameras 1744997007899-5z
Using wood instead to save time.
2024 Tacoma How to recalibrate your 360 Cameras 1745002731767-d0
Nice write-up. I see I will not be changing out my grill anytime soon.
Delta1Seven
Delta1Seven
Thanks. And if you just want to change out your grill, making that adjustment is super simple. Takes less than 5 minutes. Most people use an adjustment of +165. No need to put tape markers down or anything.
The tape and lines are used to recalibrate all the cameras together, incase they are off from factory.
Do you have a source for the procedure?
Delta1Seven
Delta1Seven
If you are just doing your grill, you can follow the steps I listed in the post.
If you are trying to recalibrate all the cameras, I also included a pdf file that has the entire procedure and goes very indepth.
I have an ALLDATA account and found this. Several options depending on what your driving.
2024 Tacoma How to recalibrate your 360 Cameras 1745005233965-
Nacho TacoMan
Paul
2025 Tacoma Limited. 2018 BMW X5 335d
I wonder if the HUD can be calibrated also? There are settings in the steering wheel to move it up/down and tilt but the way I sit while driving I would like to change the left to right setting.
What's the difference between these? Just references of initial starting positions?
Can you share PDFs of each link, similar to OPs calibration instruction file?
socaltubbs
Clint
southern CA
2025 Toyota Tacoma TRD Offroad
Notes:
Terrific detail. I am waiting for the brake line recall fix to be completed,
so I can pick up my TRD OR at the dealer. In the meantime, I am learning all of the interesting things about the truck on this forum. Thanks again for posting.
ALLDATA doesn't have PDF's, it's just webpage format which means if you have to deal with the formatting issues if you print or save to PDG. PM me if your interested in something.
This was a pain. Over three hours to get the marks done. It says it successfully saved but now it won't exit the service menu. Even after ignition stop/start.
Finally reset after turning off for at least one minute. It then prompts of you want to exit service or cancel to stay in service.
Now I just need to figure out how to get the eroor code to clear.
Delta7- I was able to bring everything back online doing it myself. But now I still have the "grayed" out service menu buttons. So I didn't know if there's a further techstream step that reactivates everything to finish the full calibration.
But at least it's operational with a football sized ball of tape in the trashcan.
Delta1Seven
Delta1Seven
I'm happy to hear you where able to get everything working withing having to pay that half day to the dealer you mentioned.
So I am not sure how to "reset" those grayed buttons. I assume that is something that needs to be done with a laptop and Techstream (or by the dealer).
However, if you hold down one of those grayed out buttons for 5 seconds, it still lets you select it. It's almost like a hidden menu.
Yes, I also had the same amount of tape, and I figured it only took me that long! I guess that's normal haha
emerica243
Matt
PA
Fusion
This seems like the thread some of us were waiting for.
So would you say if you have a OF premium and you swap to a heritage grill with rave bracket. Therefore the front camera now becoming slightly out of alignment. That following the front camera service menu flow to correct that is all that's needed?
Furthermore, I've heard after to use this method once, you can never do it again and then the whole camera circumference system needs to be mucked with or reset by GTS+.
Delta1Seven
Delta1Seven
Correct
After doing this method once, the option will be grayed out. But you can just hold down the option for 5 seconds and it will select it and you can continue as normal.
emerica243
Matt
PA
Fusion
Correct
Thank you very much. I've been sitting on $800 of a new grille setup in my basement for months because of all the unknowns here. Now I can install it.
Thanks again for your efforts and contributions here
