Sxth Element TRC1 vs. Pedal Commander
svaughn76
Plano, TX
2024 Bronze Oxide Toyota Tacoma TRD Off Road
I just ordered the Sxth Element TRC throttle response controller. At $179 it seemed like a good alternative to the $299 Pedal Commander. I should receive it in about 6 days and get it installed fairly quickly after.
Wife bought my 24 TRD
Anthony
Aberdeen Wa
I installed the pedal commander, say Goodbye to what little fuel mileage you had.
But Hey, you can burn the hell off the tires if that's what you want to do.. I
unplugged mine.
I'm gonna look for a more solid tune
CAMTuning
Cameron
New Mexico
2025 Tacoma TRD OffRoad
unplugged mine.
With the option to actually tune fuel, boost, variable cams, and transmission, I don't see why anyone would get a pedal commander. All it does is change the way the pedal and throttle plate correlate. Good call on waiting for a real tune!
Anthony
Aberdeen Wa
Serious question.....
Why?
Just put it in Sport Mode. It alters the pedal response, boost curves, shift points, and more.
Sport mode does not accomplish what I am looking to get out of it.
Unless I am actually shifting it, hypermiling it. I'm unable to get more than 14 miles to the gallon. In whatever mode, the truck is in.
I know a lot of it is all the weight that I have added, but most of it is, they lied.
CAMTuning
Cameron
New Mexico
Try out the throttle controller and see how it works. Eventually you'll probably want a real tune so that hp and tq are increased as well.
Yotota
SW WA
24 TRD
Ah, you're trying to reduce power.
Have you tried putting the truck in Eco Mode? That will do more than any pedal controller - pedal response, shift points, and boost curves. All that any pedal controller can do is electronically replicate moving the pedal more/less, or faster/slower (which can also be done with your foot).
My experience is anecdotal with my single truck:
(Stock aside from LT275/70R17 C-rated tires)
In Normal Mode, over the winter, driving mostly in hilly/mountainous terrain with 50% of my miles on snowboard trips, idling the truck, and driving 5-10 above speed limits (65mph max speed limit around here), I averaged around 17ish MPG.
In good weather, on flat ground, in Eco Mode, and driving like a grandma, I can easily hit the rated fuel economy specs. And that's what they are based on. Toyota didn't lie in my opinion. The truck, in stock form and running correctly, is capable of hitting the rated numbers under the conditions in which they were calculated.
This truck is a turbocharged 4 cylinder that's tuned to 116hp/L. That's somewhat "hot" tuning, which requires more fuel per liter to do more work compared to a larger engine that has more conservative tuning. That causes any additional load in the form of weight, aerodynamic drag, larger/heavier tires, etc, to use more proportionally more increased fuel than the larger engine would.
This is the biggest difference between a turbo-4 and a naturally aspirated V6.
For example, adding larger tires or 1000lb of stuff to a 4th Gen Taco may drop the fuel economy from 18/23 to something like 13/18mpg.
Compare that to a 2nd Gen Taco with a 4.0L NA V6, rated at 16/20 mpg. The same added load would reduce the fuel economy less, but still down to maybe 14/18 mpg.
The only good solution would be to regear the differentials with lower gears to offset some of the load and potentially larger tires. Most people don't do this because it's expensive, but it's the correct thing to do for larger tires or heavier loads.
svaughn76
Plano, TX
Why?
Because in any mode (I usually have it in Sport) there is a lag between gear shifts. I installed the TRC1 and tested it and the is now no hesitation or lag between shifting of gears. It came preset in Sport mode at Level 3 and you could tell a difference immediately. I’m sure gas mileage is going to suffer though.
Yotota
SW WA
24 TRD
Mileage will suffer, because all it's doing is simulating your foot pushing the gas pedal farther/quicker than it actually is. Which can also be done by... Pushing the gas pedal farther or quicker with your foot.
howie 522
Bryan
Martinez California
2024 toyota tocoma trd sport
I got it if u have an icon lift module for your suspension it will not work make the truck go in limo mode every light will come on and truck won’t move.
crepr12
NEast
2025 Limited Hybrid
Sport+ in my Limited is a hoot compared to the normal mode, I'll skip the pedal controllers...MPG is what it is...
Never understood spending 50k+ on a vehicle and then putting these <$300 pieces of junk on them.
Yotota
SW WA
24 TRD
Especially when our trucks have driver adjustable modes that do WAY more than any pedal controller can do.
And I'll say it again for people in the back:
The ONLY thing that these pedal controllers can do is to simulate the driver pushing the throttle pedal more or faster. Which can be done with your foot. That's quite literally all they are physically capable of doing. They are a module that plugs in between the electronic throttle pedal and the ECU, and all they do is alter the signal from the throttle pedal.
They do absolutely nothing for engine power, transmission shift points, bad breath, back hair, or anything else the companies advertise. They are snake oil, along the lines of magnets on your fuel lines or intake vortex generators.
