Retrofitting Limited OEM Power Running Boards on a TRD Off-road
cape_taco
truro ma
2025 tacoma offroad premium
Just got a '25 TRD Offroad with premium package and loving it!
I had a chance to try the power running boards (PRB) on a Tundra platinum and really liked them as well - there when you need them and not when you don't.
I know there are options for PRB like RC/Go Rhino and AMP in the after market but RC/Go Rhino use magnets that snake under the door liner and AMP don't seem available (and sound like they're slow to deploy even when they are). For these reasons and just for general OEM vibes, I'm curious about what it would take to install OEM PRB on non-limited Tacos.
So far I've found part numbers and system diagrams and it seems like you need at minimum the running boards and motors themselves and also a PRB ECU. It seems from my research that no one has successfully retrofitted this on a new gen Tacoma/Tundra/4runner yet. I'm attaching those here so other interested folks can use them if they want.
2024 Tacoma Retrofitting Limited OEM Power Running Boards on a TRD Off-road ?hash=7f308790d75cdb9ea3102cd650392aa2
Here are the part numbers for the running boards and motors:
The PRB ECU is part number 89720-35010
And here's what i found for wiring diagrams:
cape_taco
truro ma
I think that's the first step to this project is understanding if my truck has the required pigtails/harness or if I need to lay that. With that in mind:
Can any Limited owners with Power Running Boards post some pictures of the pigtail that the running board motor plugs into? Curious what it looks like and where it comes from.
My hope is that it will be as easy as buying the parts including running boards/motors/ecu, plugging them in, and initializing them. Hopefully don't need to run wires....
Bravada
S.E. Texas
There's also the switch, it's a rocker that goes from off, auto, on. I didn't realize there is also a special ECU. If someone doesn't beat me to it I'll take some pictures.
Bravada
S.E. Texas
If there is an ECU under the passenger seat, it's either tiny, or under the carpet.
2024 Tacoma Retrofitting Limited OEM Power Running Boards on a TRD Off-road 2025-06-02 22.23.30
2024 Tacoma Retrofitting Limited OEM Power Running Boards on a TRD Off-road 2025-06-02 22.22.35
2024 Tacoma Retrofitting Limited OEM Power Running Boards on a TRD Off-road 2025-06-02 22.22.02
2024 Tacoma Retrofitting Limited OEM Power Running Boards on a TRD Off-road IMG_7044
cape_taco
truro ma
Great point about the switch totally forgot about that one! Here's the entire TIS wiring diagram for the PRB and a screenshot of the switch wiring. Gotta check if I have those pigtails as well.
2024 Tacoma Retrofitting Limited OEM Power Running Boards on a TRD Off-road Screenshot 2025-06-03 at 10.39.44 AM
Thanks for all the photos! Exactly what I was looking for with the running board pigtail. I will take a closer look today when I get a chance but I didn't see any when i took a glance yesterday so not feeling super hopeful...
tkrum015
Ted
Olympia
Good job putting this all together. It may help others using other brand’s boards but the OEM switch.
cape_taco
truro ma
OK so i got down to take a closer look and its not looking good.
Front
2024 Tacoma Retrofitting Limited OEM Power Running Boards on a TRD Off-road IMG_3158
2024 Tacoma Retrofitting Limited OEM Power Running Boards on a TRD Off-road IMG_3154
Rear
2024 Tacoma Retrofitting Limited OEM Power Running Boards on a TRD Off-road IMG_3160
Any way you could find where the pigtail comes through the body and post a pic? that might be interesting to see as well.
Bravada
S.E. Texas
Here you go. I'm pointing on the door where it approximately enters the cab.
2024 Tacoma Retrofitting Limited OEM Power Running Boards on a TRD Off-road 2025-06-03 22.47.59
2024 Tacoma Retrofitting Limited OEM Power Running Boards on a TRD Off-road 2025-06-03 22.49.03
2024 Tacoma Retrofitting Limited OEM Power Running Boards on a TRD Off-road 2025-06-03 22.48.28
2024 Tacoma Retrofitting Limited OEM Power Running Boards on a TRD Off-road 2025-06-03 22.47.17
tkrum015
Ted
Olympia
Do they have two motors per side? Any markings on them other than Toyota?
cape_taco
truro ma
Thanks again for the detailed pics! Seems pretty clear that the wiring you have is coming down through one of the floor grommets near the front door and on my OR, there's nothing coming through that grommet.... Which means I'm going to need to run wires to try this. That slows things down a bunch but at least we have some intel on how this setup might work to reference for the future (or anyone else who wants to try).
Pootklopp
Usa
2024 Bronze Oxide TRD OR
Following this, I hope you can figure this out as steps are on my list now that my toddler is toddling.
Kubiedo
Seattle
Agree, also watching this thread with interest due to toddling toddlers :)
tkrum015
Ted
Olympia
The switch has 6 pins anyone know which goes to what? I see power switches e from an ECU so bet its a low voltage switch not just 12v in and out!
cape_taco
truro ma
I dont have the switch to check but since its not in the wiring diagram i would guess the other 3 pins are unused. And yeah agree it looks like its just passing ground to the prb ecu.
