Trip meter reset — HOw?!?
The Dude
Richard
Calgary, Canada
I’ve been searching the manual, flipping through settings in the cluster, and for the life of me, i can’t find how to reset the trip meter.
I like to use one for calculating distance per tsnk, and the other for checking distance to next oil change.
Help!
EVOTACO
Jay
The only way I am familiar with is to go into the meter display edit using the left side steering wheel buttons. Once you scroll to trip A or B you can hold the OK button to reset them.
The Dude
The Dude
Richard
Calgary, Canada
I must be doing something wrong. I go into vehicle settings>meters>trip a/b , and all it allows me to do is switch between time and distance. Am I in the wrong menu?
EVOTACO
Jay
Maybe. When the vehicle is on, pressing the LH/RH arrows on the left side of the steering wheel will allow you to cycle through the three customizable meter displays. Selecting the display with the trip meter showing and holding the "OK" button will allow you to enter that meter display and edit the layout. You may also have to use the UP/DOWN arrows to cycle through the different available info options to display the trip meters. Use the LH/RH arrows again to highlight the trip meter. A prompt to reset will appear. The reset does both time and distance.
2024 Tacoma Trip meter reset — HOw?!? 1749327485703-39
2024 Tacoma Trip meter reset — HOw?!? 1749327547536-if
The Dude
The Dude
Richard
Calgary, Canada
Huh, maybe it’s a Canada/US thing, but I don’t get those different selections. I’m probably doing something way wrong, so I’ll keep banging away at it.
Hero status to @EVOTACO pictures really helped me try and work on this. I’m going to have to sit for a while and see what’s what. Thanks brother!
CrispyTacoLover
It’s overly complicated. Toyota software UI sucks.
Try and find a video. If you can’t find one on the subject, maybe I’ll make one on the next fillup.
EVOTACO
Jay
Interesting. Didn't really think about the possible US/Canada differences. They might just be turned off. There is an additional ON/OFF toggle menu for the additional gauges available to display.
Same process to get to it as above. Depending which side they are being accessed from.
I have mine on the LH side, but all of the same displays are available on the RH side as well.
Notice the additional scroll lines on the left...
2024 Tacoma Trip meter reset — HOw?!? 1749330302226-b8
Pressing the LH arrow at this point will open the toggle menu. Use the UP/DN arrows to scroll through the available displays and select OK for the ones wanted. The selected displays will now be available when scrolling with the UP/DN arrows in the previous screens above.
2024 Tacoma Trip meter reset — HOw?!? 1749330389265-sz
The Dude
The Dude
Richard
Calgary, Canada
@EVOTACO That did it!! Thank you, thank you, thank you! Had to back out of where I was, then I could go to the left and found the trip meter. Awesome. Have a virtual beer on me.
Dansflhti
Nova Scotia
Help!
This is the configuration I use...but I couldn't for the life of me tell you how to do it..lol. But it is available on your CDN truck.
Texas Bob
Bob
This is one of the most irritating things about the truck (and I assume all new Toyotas): it shouldn't be that difficult! I spent way too much time figuring this out, and now that I know, it's such a pain that I will rarely bother to reset either tripmeter. I'll just live without it. Thanks, Toyota! BTW I thought that the ultimate answer to the OP was going to be that you must be stopped with the engine running, parking brake engaged and/or in Park, because SO MANY things require this.
I'm struggling to see the concise answer, so I'll try to put it here for others:
1. be on your dash view (1-2-3) that contains the trip you wish to reset
2. long press the steering wheel OK to trigger edit mode
3. toggle right/left to your desired trip counter (if you don't have it displayed, then toggle up/down until the trip counter is displayed)
4. as instructed on the screen below the trip counter, now long press the steering wheel OK to trigger a counter reset
5. hit steering wheel back button until you've exited out of edit mode fully
Takes longer to get to the trip history view in the main screen and update/reset that
1. tap to view Toyota menu
2. tap vehicle icon
3. tap over to history
4. tap update
5. exit back to your normal screen (toyota/ACP/AA/etc.)
Pappy
Albuquerque, NM
You might want to get familiar with this fella's videos.
2024 TRD Sport-Bronze oxide.
My Versa had a small stalk that stuck out from the dash. Push once, trip A, push again, trip B, Hold......clears either one. Sometimes the old tech is the best!
EVOTACO
Jay
Just needs a Step 3.1 describing how to enable the trip display if they do not appear during the UP/DN toggle.
Fair.
Assumption was that if you're asking how to reset them you've already got it displayed.
