Bed Lighting/Scene Lighting - Electrical Connections/Diagram
robfultz
Rob
2024 Tacoma Off Road
I really like the Trail Hunter Bed Scene lighting, but as many have noted in prior threads Toyota appears lacking parts for mods and the aftermarket is not there yet.
I do a lot of surf fishing (drive-on beaches) and some times at night & seeing around the bed would be helpful.
I am considering trying something on my own but have a few questions.
I want them to work on same switch as the existing bed lights, or find a constant electrical feed and possibly add a on/off switch at the tailgate.
I do not want to use the existing rear wiring harness (other plans for that).
1. Anyone have a wiring schematic for the rear bed lights or the rear of the truck?
Would like to find a tap point for the...
- Bed light switch
- Constant feed in the rear of the truck (for use if I add a on/off switch)
2. Existing side wall bed lights (internal to the bed)
Anyone know how to remove these lights without breaking them?
Rob
FYI - 2024 Tacoma Off Road
Delta1Seven
I don't have much info to give, but do you plan on using the OEM sceen lighting parts? Or are you going get your own lighting?
I've been considering doing the same thing for camping and such, but I haven't decided on what lights to go with and where to mount them.
co425
Brandon
BMW Motorcycle
I’m really interested to see if there are factory wiring connections for the bed scene lighting. Anyone find them yet?
robfultz
robfultz
Rob
I am looking at perhaps modifying my existing bed rails if I can find LED lights that would look similar, but the issue would be how to direct the light downward. The current bed rail has an angle such that the LED beams would project slightly upward or straight out, not down like i would prefer.
Then you also have the wheel well that projects out blocking direct light from getting to the ground close to the truck.
I am also looking at possibly LEDs in the back of the wheel well projecting outward thru the clearance on both sides of the rear wheels, but they would likely not survive rocks/debris coming off the tires.
I may just wait till the Trail hunter style are available.
I would like to find out if the bed lights on the side of the bed on the interior, are removal to tap there for power. I tried prying around them, but I am afraid to force and damage them.
Delta1Seven
Good points on all that you mentioned. Please do update us if you end up getting some lights install, however you do it!
I also considered waiting on the OEM Scene lighting, but I expect them to be fairly expensive considering I would need new bed rails, lights, and wiring harnesses.
I have also considered rock lights and mounting them either in the wheel wells like you mentioned, or just underneath around the truck.
Amazon has some cheap ones: https://a.co/d/0KaBAhg
Baja Designs makes 180degree rock lights: https://www.bajadesigns.com/products/led-rock-light/
Delta1Seven
Interestingly, I just found the below photos. And although they look bright, I didn't realize how many shadows they cast. Perhaps a DIY solution may yeild better results
2024 Tacoma Bed Lighting/Scene Lighting - Electrical Connections/Diagram 1750466056694-el
2024 Tacoma Bed Lighting/Scene Lighting - Electrical Connections/Diagram 1750466064517-c8
robfultz
robfultz
Rob
Ok here is what I did.
My main objective was to light up the area on the ground around the truck for surf fishing at night with bait buckets & coolers on the sides.
Bought a set of IP67 rock lights & attached to the bottom of the fender flares after I removed some of the plastic. I wanted something that you wouldn’t know that was there & wired into the bed lights so they work with the switch for the bed lights.
They do a great job but I’ll see how long they last. They also sit on the lip so not interference when the tire flex’s up into the wheel well.
Only improvement I may do is re-wire them to use a battery from a switch in the aux box in the bed.
The lights are below & cover more area than I expected. Also my tires have about 1.5” of poke, so a little shadow.
Rob
2024 Tacoma Bed Lighting/Scene Lighting - Electrical Connections/Diagram IMG_0368
2024 Tacoma Bed Lighting/Scene Lighting - Electrical Connections/Diagram IMG_0365
2024 Tacoma Bed Lighting/Scene Lighting - Electrical Connections/Diagram IMG_0366
2024 Tacoma Bed Lighting/Scene Lighting - Electrical Connections/Diagram IMG_0367
2024 Tacoma Bed Lighting/Scene Lighting - Electrical Connections/Diagram IMG_0363
2024 Tacoma Bed Lighting/Scene Lighting - Electrical Connections/Diagram IMG_0362
