Trailhunter with Decked Storage - Air Compressor Clearance
bemmster
2025 Trailhunter Long Boi
Hey guys!
Looking to put in a decked system into my Trailhunter long bed. To anyone running this setup, what did you do about your air compressor? Did you make modifications for it? Can you post up some pics?
Need some ideas on different options to get a clean install and still keep full functionality of the air compressor.
Thanks!!
Trailhunter Mark
Mark
Orlando, Florida
Absolutely do not follow the Decked instructions for the compressor. I did start to follow the instructions & pulled the compressor panel completely out, but was like, no way! Instead, I made a small U-shaped cut in the Decked top panel (for the hose to connect). Next I unscrewed & removed compressor control panel door & glued some strong magnets on the panel door & inside the panel (so the panel door stays in place even when on trails). Now, I have lots of storage space, the compressor works like a charm, & the truck bed looks great!
2024 Tacoma Trailhunter with Decked Storage - Air Compressor Clearance IMG_4547
2024 Tacoma Trailhunter with Decked Storage - Air Compressor Clearance IMG_4548
2024 Tacoma Trailhunter with Decked Storage - Air Compressor Clearance IMG_4549
2024 Tacoma Trailhunter with Decked Storage - Air Compressor Clearance IMG_4550
2024 Tacoma Trailhunter with Decked Storage - Air Compressor Clearance IMG_4546
Mjsimmons
Jim
West Michigan
2024 Tacoma Trail Hunter
Hey guys!
Thanks!!
I have installed a cap on my Trailhunter's 6' bed. So, I removed the compressor access cover. I needed to do some minor grinding to remove some of the Decked underside ribbing... this allowed enough room for a 45 degree fitting on the airhose. I leave the hose connected under the deck.
2024 Tacoma Trailhunter with Decked Storage - Air Compressor Clearance 20250215_110357
2024 Tacoma Trailhunter with Decked Storage - Air Compressor Clearance 20250215_110347
bemmster
bemmster
I really like this, very clean looking. Does the port cover basically just pop off after the modification? Seems like it would be hard to pull off though, like it would be hard to grab a hold of unless i'm missing something.
Trailhunter Mark
Mark
Orlando, Florida
No problems at all… Once you remove the left side cargo panel (which has to be opened/removed to plug in the air compressor hose), the panel just pops off. It will also pop off from underneath as well.
