Does your Tacoma Bed Rattle on Certain Bumps?
james cole
Bronco
Hello Guys,
Wondering if your Tacoma bed is doing the same:
My bed rattles when going over fast shallow bumps in the road, if I do a speedbump it wont rattle.
I can only reproduce this noise on what seems to "upset" the bed a bit...
The noise is loud enough I can hear it with the windows up, suspension seems to be torqued properly.
Is this normal in a Truck Bed?
Thanks
JC
mtbocoee
Ocoee, TN
2025 Tacoma Trailhunter, 2000 Tundra, 2013 Highlander
I have heard something similar in my Trailhunter, but only on certain bumps. I cannot reproduce either and I haven't been able to pinpoint it. It sounds like it is behind me and coming from the bed.
Check your console box and make sure nothing is rattling in there. The walls are hard plastic and if there is something solid in there it resonates.
Halifax, NS
2025 TRD Pro
Hello Guys,
Thanks
JC
Do you have spray in liner?
mtbocoee
Ocoee, TN
I have a spray on liner as well.
I haven't noticed this recently, but I have since installed a bed liner, full bed Molle panels, Hi Lift jack mounted to the rails, gas cans on the front Molle, and an Alu-cab Contour Canopy as well as some other items in the bed. Perhaps the weight makes a difference.
DaPinkCat
NOA
San Diego
2023 TRD PRO
Hello Guys,
Thanks
JC
My 23 OR rattled. I put rubber washers under it. Literally go under truck, find bolts, put rubber washers between bed and metal. I found it on YT.
james cole
Bronco
I kind of want to think its normal but am not sure, its been a long time since I had a pickup, the rattle or noise does not happen when going over a speed bump, only when hitting uneven sharp bumps... sounds more like the whole bed shaking.
james cole
Bronco
Thanks... currently is empty.
You have to have very crappy roads and hit bumps certain way in order to hear the noise, nothing major but still there and wanted to know if its normal, not sure if Pros are more susceptible to this since they are lifted from the factory.
jrodz2223
chuy
texas
tacoma
Do you have a tow hitch? Mine does that too, over certain bumps or potholes it rattles in the hitch receiver.
