Looking for pinout for Qi Charger wiring harness on 2025 Trailhunter
towline76
Miles
SF Bay Area, CA
2025 Tacoma Trailhunter
I want to replace the Qi charging pad with something else and use the wiring harness to power it, so I need to understand the pinout for that wiring harness.
Can anyone here point me to that info? I bought a wiring schematic, but maybe I've forgotten more about electronics and schematics than I thought I did. I can't seem to parse the schematic (attached) to understand which pins are the positive & negative power lines.
Any info is greatly appreciated!
2024 Tacoma Looking for pinout for Qi Charger wiring harness on 2025 Trailhunter s-l1600-1
2024 Tacoma Looking for pinout for Qi Charger wiring harness on 2025 Trailhunter s-l1600-3
2024 Tacoma Looking for pinout for Qi Charger wiring harness on 2025 Trailhunter Screenshot 2025-10-23 at 10.15.32 AM
Ron
Samsara
Im not sure about the schematic but how many pins are on the connector for the charge pad?
In the picture above, not clear but it looks like 2 - which is all it really needs.
towline76
Miles
SF Bay Area, CA
I wish it was that easy.
There are eight pins.
2024 Tacoma Looking for pinout for Qi Charger wiring harness on 2025 Trailhunter IMG_6796
  • Wow
Reactions: Ron
Ron
Samsara
You didnt ask for a guess but here is mine.
Pin 1 - Ground
Pin 2 - unused
Pin 3 - Key-on power (accessory)
Pin 4 - Battery (+12)
Pin 5 - Canbus High
Pin 6 - Canbus Low
Pin 7 - TAIL ? Possible for the charge indicator
Pin 8 - Smart key ECU
You probably want accessory power but i'm not sure i would put a load directly on that. The factory charge pad is also getting +12 battery so it may be using Accessory to activate a solid state relay for charging power.
towline76
Miles
SF Bay Area, CA
It is. I am removing the charge pad and want to use its power connection to provide power to something else with similar electrical specs.
towline76
Miles
SF Bay Area, CA
Pin 1 - Ground
Pin 2 - unused
Pin 5 - Canbus High
Pin 6 - Canbus Low
That certainly looks like a ground symbol on pin 1. I agree that pins 3 & 4 seem to be 12v.
It’s pretty confusing to me why the charge pad needs all those connections. AFAIK, it’s not communicating with anything, just energizing a Qi charging pad.
I suppose I’ll test running 12v through pins 3 & 4 individually from a bench power supply and see if the Qi charger gets power.
