TrustButVerify
central
Several
I over heated my transmission when I was off roading. I was only at 5000 miles but decided to change it just in case. The fluid was a bit used but not terrible. I probably could have gone longer on it but once I was in it, I just completed it.
Same for me. Surprising how quickly 4HI roasts the transmission temps. The moment the temp hits 220F, the dash gauge moves up, and it moves up quickly from 220F to 250F. And it stays hot for a long time. Even switching to 4LO, which helps some, kept the fluid temp fairly high for a long time. Not sure if there's any active cooling on this or not, but it doesn't seem to have any.
559Taco
New Taco
Fresno
2025 Tacoma
I finally just ordered an auxiliary transmission cooler to deal with the issue.
Reconsnake
Jake
Sacramento CA
2024 Tacoma Off Road Premium
I am interested in which one you went with, and of course an after install report on its effectiveness, if you would be willing to update us.
559Taco
New Taco
Fresno
2025 Tacoma
Derale 13740 Hyper Dual-Cool Remote Cooler. I'll let you know how it works after the install.
TacoToni
Gary
Leona Valley, CA
2024 Tacoma SR5 4x4 Celestial Silver
I tried doing this today but I didn’t find the internal standpipe. I ended up replacing the same amount of fluid that I removed, which was about 600ml. Any ideas of why I didn’t find the standpipe?
559Taco
New Taco
Fresno
2025 Tacoma
I'm not sure. That's strange.
TacoToni
Gary
Leona Valley, CA
Do you think it takes a 6mm hex to remove the stand pipe instead of a 5mm? Cause today I had to use a 6mm just to remove the metal plug but you have 5mm listed
TacoToni
Gary
Leona Valley, CA
So I did the fluid change and it’s a 6mm hex for both the drain plug and the stand pipe
559Taco
New Taco
Fresno
2025 Tacoma
Perhaps I thought it was a 5 but it was a 6. I can't remember at this point.
