Cabin Power/Fuse Tap help
Delta1Seven
I'm looking for a suggestion on where to tap into power inside the cabin. The fuses under the passenger foot well have no extra room, as the cover sits flush over the fuse panel (no extra space for fuse taps).
Are there any other locations I can tap into for 12v power?
Pappy
Intermountain West
Why don't you want to use one of the vacant circuits from one of the fuse boxes under the hood? It's easy to get the wire from under the hood to under the dash, at least on the passenger side.
Behind the battery, where the harness comes through the firewall, is a nipple on the grommet. Cut the tip off the nipple and run the wire through.
The circuits marked in yellow are constant power. If it's not marked it's switch power. Pick one. The two circles are 1/4" spades that are hot. They just need to be fused. You can see the fuse tap I used on a vacant switched circuit.
SkinnyT
Bryce
California, US
2025 Bronze Oxide Tacoma TRD Sport
Some context would help..
-What are you using it for?
-Location?
-Do you need switched and/or constant 12v?
-etc..
Anyhow, there's a few spots tbh. Could just use the 12vdc "cigarette lighter" ports. Or there's one spot that was extremely useful for me. It wasn't used on my trim at all, but still wired up and fused from the factory. It's an empty white connector above the driver's side map light. You have to pop out the map light assembly (very easy to do, just some clipsβ€”google the Meso Customs video on YouTube of how to install their aftermarket map lights if you're still uncomfortable, they pop it off in that video). Connector is "Option Connector W20" ...Not sure if you have TIS, but..
"W20" location:
β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”
This is the connector:
Pins 1, 2 and 4 are what you're looking for.
Wiring Diagram:
Pin 1 is your constant +12v
Pin 2 is your switched(ACC) +12v
Pin 4 is your GND
LA-B = Lavender/Black wire
LA-P = Lavender/Pink wire
LA-SB = Lavender/Sky-Blue wire
β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”
Depending on what you need it for though this spot might be pretty inconvenient lol. Thats where context would help.
-T
Delta1Seven
Delta1Seven
Thanks for this. I actually ran power through the grommet on the driver side (for my Auxbeam panel). But I didn't want to run another cable thru as I feel those grommets only seal around 1 cable, not 2.
I didn't even realize there was a 2nd grommet on the passenger side. I think I may just run it through there!
Delta1Seven
Delta1Seven
-Location?
-etc..
"W20" location:
Wiring Diagram:
Pin 4 is your GND
-T
I think I'm going to go this route. I just ordered this, but I'm going to snip off the tail end of this so I have the wires exposed (I don't want to splice into the existing harness).
Do you happen to know what fuse W20 runs off of? I just want to confirm it's not like airbag or safety sense or anything.
