Will 2025 Tundra 22” wheels fit?
BobbyG
Bob
Valrico, Florida
2025 Tacoma TRD Sport
Does anyone know if a 2025 Tundra‘s 22” wheels will fit on a 2025 Tacoma TRD sport. The Toyota dealer says they “SHOULD” fit because they both have the same part number in his parts directory. He says there might be a problem with the brake calibers cause the Tundra has bigger brakes. He’s not sure. I have a great deal pending on a new set, but I need to be sure cause once I buy them they’er mine. I had the same rim and tire size on my two 2nd gens and on my three 3dr gens, but I’m told the 4th gen is different. Looking for advice.
CrispyTacoLover
The center hub and lugs should fit fine but why would you want 22’s ??? Do you live in Houston or Hawaii ?
BobbyG
BobbyG
Bob
Valrico, Florida
No, I don’t live in Houston or Hawaii, I live in Florida. I’m a 78 year old dude that loves the old school style, like chrome and whitewalls. I can’t handle little black rims with big balloon tires that have deep treads, cause I don’t do dirt roads or drive through mud puddLes, I like my 22“ rims chrome and shinny along with all my other chrome. I take it your question to my question means you don’t know the answer to my question. Right?
Droid
Wyoming
25 OR MT
Capstone wheels? Looks like they have a 60mm offset. I think the OEM Sport wheels are 55mm offset (just like the offroad). So they will be 5mm more tucked in than the Sport wheels. Looks like they're 8" just like the offroad wheels.
I would imagine they clear given that people have no trouble running 285/70R17 on TRD offroad wheels that would have the tire closer to the inside.
The OE tires on these are 265/50R22 which are 32.4" tall, imagine that'd be no problem.
Take this with a grain of salt, I've never had a wheel larger than a 17. But numbers wise I think they work.
Ride might be a bit rough. Haven't driven a 4th gen sport but had a 3rd gen sport rental once and ride was firm with its 17s.
Thbxx
2024 Toyota Tacoma
If it were me, I’d test-fit a wheel first to confirm hub and caliper clearance. If you can’t test-fit, treat the deal as risky, you may need rings, lugs, or spacers, and the 22″ setup may not ride like stock.
Rendusk
Marv
Port St Lucie, FL
Tacoma 2025
I run 20's, I don't see why the 22's wouldn't work.
Also, same. I'm soflo and run a sporty look on my 4G
BobbyG
BobbyG
Bob
Valrico, Florida
Tundra 22 inch Capstones are a perfect fit for my 2025 Toco. TampaBay Toyota confirmed the fit, and they ride the same as the original 18s. I’m a happy old Dude today. Thanks much Droid for your input.
2024 Tacoma Will 2025 Tundra 22” wheels fit? IMG_0407
2024 Tacoma Will 2025 Tundra 22” wheels fit? IMG_1786
2024 Tacoma Will 2025 Tundra 22” wheels fit? IMG_0383
gfk
2026 OR Tacoma
Not my style BUT that does look pretty awesome. I'm in Tampa... If you get honked at by a mudbath offroad then that was me!
