Anyone know if the Toyo Open Country 35x11.5 fit without rubbing? I know the 285/75/17 fit and they are 33.9" vs the 34.5" which seem like they should but I haven't seen any posts on this.
That's what I'm thinking I just havent seen anyone on here mention that size. I know weight is a big consideration so maybe thats whyI would be surprised if they didn’t.
35X12.5 fits with minor front wheel well trimming and crash bar removal for full flex. thinking you might be OK?That's what I'm thinking I just havent seen anyone on here mention that size. I know weight is a big consideration so maybe thats why
I think so. I'm getting new wheel next month when I get back from vacation. If I get these I will update35X12.5 fits with minor front wheel well trimming and crash bar removal for full flex. thinking you might be OK?
You might be right. Your tires are 34.3" and 11.8" in width vs the 34.5" and 11.4" on the 35x11.50r17 its the closest comparison, I think. How much more lift does the wescott design level kit give you?Ohoh, then thats going to give you some lift, my apologies, didnt realize you were able to get the factory lift,….that probably will be doable then, im curiouse, the specs on factory lift are, 2-2 1/2. Lift from what i heard, i still think you will need to remove crash pads,
This looks really good! The stock 265/70r18 Falken at3w my truck came with just looks small on the factory lift and when I saw that the Toyo 35x11.5 are only 0.6" taller than a 285/75r17 that I know for sure fit I wanted to see what others thought. The factory 2.5 lift wasn't an option you could add from the website builder till now on the 2026 so there was no specs and dealers around me didn't really say much or advertised that you could spec it if you got one from allocation. Per the website builder the lift "offers a 3" lift in the front and a 2" lift in the back, providing 2.6” of additional ground clearance overall."I have stock suspension with dobinsons springs front and rear. Approximately 2” up front and 1” at the rear in lift. I have method 305 with plus 25 offset. I put 35 12.5 17 on and the only thing I had to do was remove the crash bar. No rubbing whatsoever. I don’t know what the factory lift is but if you get at least 2” or more then you should be good.![]()
Oh, with that amount of lift you shouldn’t have any issues. If you’re sticking with oem wheels (I can’t remember) then everything should be fine. If you do aftermarket wheels then the sweet spot for offset seems to be +25 or +35. I’ve seen some do a zero offset but they usually have trimming to do. Best of luck. I’d ask about that diff bushing just to see what Toyota does about it when they put a lift on. Most anyone who does a lift has to replace it.This looks really good! The stock 265/70r18 Falken at3w my truck came with just looks small on the factory lift and when I saw that the Toyo 35x11.5 are only 0.6" taller than a 285/75r17 that I know for sure fit I wanted to see what others thought. The factory 2.5 lift wasn't an option you could add from the website builder till now on the 2026 so there was no specs and dealers around me didn't really say much or advertised that you could spec it if you got one from allocation. Per the website builder the lift "offers a 3" lift in the front and a 2" lift in the back, providing 2.6” of additional ground clearance overall."
Thanks for sharing. The lift actually came installed from Toyota. The lift wasn't an option on the builder till now, but some dealerships were allowing you to spec it with that which is what I did. When I get back and install tires, I will take a look at the cv bushingOh, with that amount of lift you shouldn’t have any issues. If you’re sticking with oem wheels (I can’t remember) then everything should be fine. If you do aftermarket wheels then the sweet spot for offset seems to be +25 or +35. I’ve seen some do a zero offset but they usually have trimming to do. Best of luck. I’d ask about that diff bushing just to see what Toyota does about it when they put a lift on. Most anyone who does a lift has to replace it.
https://www.tacoma4g.com/east-coast-gear-supply-diff-bushing-diy-install/
